how do i know?
how do i know? by lyndbo on Tue Mar 04, 2008 9:23 pm
how do i know if the primer pump is going?
on my previous 2.3 you could pump it but then it would get harder
on my 2.8 you can pump and pump and it wouldn't get hard.
which one sounds like its working????
lyndbo
Re: how do i know? by The Engineer on Tue Mar 04, 2008 9:29 pm
:D they all get hard to pump if they are working ok sounds like the pump diaphram is stuffed :D
Sounds like a tractor But goes like a rocket - Poor mans auto parts.
The Engineer
Vehicle Name: Dragon
Modifications: suzukigrand vitara 1.9DTI
Re: how do i know? by lyndbo on Tue Mar 04, 2008 9:31 pm
is it best to get a new prime pump or the diaphram?
lyndbo
Re: how do i know? by Drift on Tue Mar 04, 2008 9:42 pm
My pump presserer in thing only shows slightly more resistance when pumped, but the old girl runs like a dream so Im leaving it alone :lol:
Re: how do i know? by lyndbo on Tue Mar 04, 2008 9:51 pm
you see mine is running dia,only getting upto 2500-3000rpm,and it starts to lose slight power.
lyndbo
Re: how do i know? by Drift on Tue Mar 04, 2008 9:57 pm
Thats it then as he said, its knackerd :wink:
Re: how do i know? by Trugga on Tue Mar 04, 2008 10:43 pm
Surely, the primer pump is only used to bleed the air out of the fuel having changed the fuel filter (or having run out of fuel)
Re: how do i know? by Drift on Tue Mar 04, 2008 10:45 pm
If the diaphragm is split or torn it will allow air in.
Re: how do i know? by willowkevin on Thu Mar 06, 2008 1:04 am
apologies if im wrong , but doesn't the pump bit go downwards when knackered ? like up n down whilst you rev ? i dont think the fact that it doesn't go hard indicates primer pump failure , i think thats the diaphram "vaccuming" as the fuel cant flow with the stop solonoid switched off !
frontera 2.8td hybrid
willowkevin
My car is mostly a Frontera
Vehicle Name: molliemobile
Modifications: hybrid isuzu 2.8td .5th year on still going strong ...
Re: how do i know? by markta on Sat Mar 08, 2008 4:46 pm
i know this has got nowt to do with a prime pump but are you sure thats the problem :?: as if its only revving between 2500-3000 rpm it sounds to me that its more likley that the pipe to your turbo is either loose or has a split etc in it,as this would make it lose power & stop it revving.as trugga said the primer pump is for bleeding the air out after filter change etc etc
i,ve said this before,i dont even use the primer pump,it is much easyier to cut the fuel line from the filter to the pump & insert a hand pump,so if you ran out of derv or after a filter change 2-3 pumps sorts it & engine fires as it should........
markta
