Frontera Technical Support • View topic - Fault code p0405 - help please
Fault code p0405 - help please by sciroccotune on Sun Mar 02, 2008 7:26 pm
HI guys
after finding my diagnostic port i was able to read the fault code that is causing the engine light to come on.
p0405 - exhaust gas recirculation sensor "a" circuit low
can anyone suggest how to approch this?
Vauxhall last scanned the car and said that it was an o2 sensor (of the 4 i have replaced 2 recently) but this error code seems to suggest something else?
any ideas?
thanks.
sciroccotune
Re: Fault code p0405 - help please by meooo on Sun Mar 02, 2008 8:33 pm
Test procedure on autodata goes;
Wiring short to earth
EGR valve position sensor defective
Or ECM fault
If that helps
meooo
Cookie monster
Cookie monster
Vehicle Name: dead
Still sporting Salisbury mud
Gone to meet its maker :(
Skype Username: john.hird8
Re: Fault code p0405 - help please by nitromotor on Mon Mar 03, 2008 12:22 am
Check egr plug connections are clean
Measure the voltage at the plug (harness to the EGR valve) wire that’s black with yellow stripe and ground. Above 11v
Red and ground 4.8 v
Red to green 4.8 v
It’s also worth removing the EGR and cleaning carbon away
Re: Fault code p0405 - help please by sciroccotune on Mon Mar 03, 2008 12:33 am
cool ill take a look chaps, do we know if it is easy to get to on the 3.2 v6?
sciroccotune
Re: Fault code p0405 - help please by nitromotor on Mon Mar 03, 2008 12:41 am
its ok to get to but
Read this link
viewtopic.php?f=22&t=8862
There is a photo some place....
Re: Fault code p0405 - help please by sciroccotune on Mon Mar 03, 2008 12:52 am
Thanks for that, will make sure i take it easy on the studs!!! Hopefully this will clear the problem and i can have a few months of engine light free fronty ownership :roll: :lol:
sciroccotune
Re: Fault code p0405 - help please by nitromotor on Mon Mar 03, 2008 3:47 am
Spray some penetrating oil on them over a few days prior to removing them.
Re: Fault code p0405 - help please by sciroccotune on Mon Mar 03, 2008 12:59 pm
will do, ill have a look for it tonigth if i get the chance. FYI if any one north east needs there codes reading and resetting im happy to help
sciroccotune
Re: Fault code p0405 - help please by nigelbread on Tue Nov 25, 2008 12:35 am
nigelbread
Modifications: +
