Head gasket
Head gasket by woody666 on Sat Mar 01, 2008 2:43 pm
Hi..water pump started to leak,have replaced it..then expansion tank split..this might be problem....the one fitted had 2 small hose connections at top and 1 middle size @ bottom..have replaced with tank that has one hose @top (hose connect to injector manifold) radiator overflow hose connects @ bottom along with middle size hose..since replacing Head gasket has GONE west ...is it wrong expansion tank to blame or just one of them things ...cheers
woody666
Re: Head gasket by The Engineer on Sat Mar 01, 2008 2:53 pm
:( Just one of those things but I would try to get the right header tank :D
Sounds like a tractor But goes like a rocket - Poor mans auto parts.
The Engineer
Vehicle Name: Dragon
Modifications: suzukigrand vitara 1.9DTI
