Frontera Technical Support • View topic - brake bias valve (load sensor)
brake bias valve (load sensor) by colin all on Tue Feb 26, 2008 10:54 pm
can anyone help me. I'm trying to work out if the load sensor is working or not, as you look at the valve itself the lever is pulled all the way towards the axle, is it actually pushed out (away) from the rear axle when under braking, bit difficult to check this myself (billy no mates) any help would be appreciated.
thanks
colin
1999 LWB 3.2 V6 petrol/LPG
colin all
Registration Year: 1999/S
Modifications: Marrelli LPG conversion from Hytek
Heavy Duty rear springs
Re: brake bias valve (load sensor) by Drift on Tue Feb 26, 2008 10:58 pm
If your brakes lock up, you could have a problem, do the brakes feel normal ?
Re: brake bias valve (load sensor) by colin all on Tue Feb 26, 2008 11:05 pm
the only time they've locked up is when towing a caravan, but i did need to stop unexpectedly
colin all
Re: brake bias valve (load sensor) by john (smifffy) on Tue Feb 26, 2008 11:11 pm
Re: brake bias valve (load sensor) by Drift on Tue Feb 26, 2008 11:17 pm
In that case it seems to be working fine, the bias valve sences the load on the rear axle and adjust the brake pressure acordingly.
