liffting points for a hi lift jack
liffting points for a hi lift jack by dickycaz on Sun Feb 24, 2008 8:38 pm
i was looking at a hi lift jack for my truck . so were do i put it to lift my fronty do i have to fit jacking points or will the metal bumpers be strong enough :twisted: :twisted:
dickycaz
Modifications: 2.3 td lwb
Re: liffting points for a hi lift jack by TheBig-D on Sun Feb 24, 2008 8:59 pm
Almost sure carl 'Red oktober' lifts his from his bumpers.
TheBig-D
Re: liffting points for a hi lift jack by alex on Sun Feb 24, 2008 9:26 pm
Ive seen Fronties up in the air off bumpers, but wouldnt myself. The rear chassis is easy to access and a good lift point could be put on either corner and even center if you dont have a tow bar.
Front and sides are a bit tricky as it must drop from Chassis before coming out.
Re: liffting points for a hi lift jack by Red Oktober on Sun Feb 24, 2008 10:03 pm
lifting off the rear bumper with a "Hi-lift" ...been there done that
Re: liffting points for a hi lift jack by yaki on Mon Feb 25, 2008 11:09 pm
Lifted the front on the Bullbar :shock: :shock:
No problems, just make sure the handbrake is on proper like :!:
Did try the back as Carl demonstrated on my breaker, make sure you chock the front wheels and the jack doesn't try and lift both rear wheels off at the same time :!: :!:
Re: liffting points for a hi lift jack by Red Oktober on Tue Feb 26, 2008 10:09 am
There was concrete blocks to stop it rolling forward
on my pic .....theres 5 holes left till the top of the jack ....and the rear wheel is only 2" clear of the ground :shock:
