Frontera Technical Support • View topic - Outside Temperature Sensor "B"
Outside Temperature Sensor "B" by Paul A on Fri Feb 22, 2008 11:29 pm
Hi,
Anyone know exactly where the temp sensor (the one that gives the outside temp on the multi - display) is located on a Frontera "B"?
Bu***red if I can find it!
:shock:
V6 Isuzu Vehicross
Paul A
by Red Oktober on Fri Feb 22, 2008 11:32 pm
by Paul A on Fri Feb 22, 2008 11:45 pm
V6 Isuzu Vehicross
Paul A
by Drift on Fri Feb 22, 2008 11:47 pm
by BUMPTJ on Sat Feb 23, 2008 12:13 am
BUMPTJ
The Parts Man
by Drift on Sat Feb 23, 2008 12:20 am
Yer I know about that one Tim :wink:
Im positive Ive seen a pic of a temp sensor near the bumper on a B :wink:
by nitromotor on Sat Feb 23, 2008 12:42 am
by marlbororman on Sat Feb 23, 2008 1:16 am
yer it is between the radiator and the grill, i know coz i got my radiator out at the minute, engine out tomorrow :cry:
Member no. 705
marlbororman
by Drift on Sat Feb 23, 2008 1:16 am
Ian :shock: what now mate :?
by marlbororman on Sat Feb 23, 2008 1:20 am
Member no. 705
marlbororman
by Drift on Sat Feb 23, 2008 1:25 am
by marlbororman on Sat Feb 23, 2008 1:30 am
Member no. 705
marlbororman
by Drift on Sat Feb 23, 2008 1:40 am
by marlbororman on Sat Feb 23, 2008 1:49 am
Member no. 705
marlbororman
by Red Oktober on Sat Feb 23, 2008 9:50 am
by Paul A on Sat Feb 23, 2008 11:12 am
V6 Isuzu Vehicross
Paul A
by Paul A on Sat Feb 23, 2008 12:12 pm
Fixed!...... now have temp display!
Funny how much you use this and not notice until it's not there anymore!
Got the new sensor from this guy on Ebay.
He has some good Fronty parts and the prices are really cheap.
eBay Link
Edit (Trugga): Link text reduced to preserve forum layout
V6 Isuzu Vehicross
Paul A
by Trugga on Sat Feb 23, 2008 12:16 pm
Well done Paul.
Did you work out how to remove the B's grill ? (I'm only familiar with the A)
by Paul A on Sun Feb 24, 2008 8:53 am
Hi,
Eventually! There are two spring clips in the engine bay.
Just tight enough to NOT be able to release with your fingers, and just so inaccessible that you can't get pliers on them!
They are square in section, fortunately I had some bits of square section brass tubing laying around in the shed.
One of them was just the right size to push over the clip and compress it enough.
There's probably a special Vauxhall tool to do the job at several billion pounds ......... :roll:
Stupid thing is, if you need to replace a front indicator bulb (reasonably common occurance I would think) ...... Yes....... you have to ........ Remove the Grille! :roll:
V6 Isuzu Vehicross
Paul A
Re: Outside Temperature Sensor "B" by nitromotor on Mon Feb 25, 2008 12:38 am
Thanks for posting back to let us know how you got on. :D
