Frontera Technical Support • View topic - catalytic thimgy
catalytic thimgy
catalytic thimgy by deanojul67 on Thu Feb 14, 2008 2:31 pm
Dean'o
2.0 sport A series k reg
If i had a sense of humor i would have bought a landrover
or kept the pajero
deanojul67
by BUMPTJ on Thu Feb 14, 2008 2:38 pm
BUMPTJ
The Parts Man
?? by deanojul67 on Thu Feb 14, 2008 3:02 pm
Dean'o
or kept the pajero
deanojul67
by BUMPTJ on Thu Feb 14, 2008 3:19 pm
It should be fine then. Its probably the heat shield which has the hole, if it faces the floor no probs. If it faces the underbody then you need to patch it
Inside the cat it normally has 3 ceramic monoliths(basically blocks) which are honeycombed. This honeycomb is coated with precious metals(which is why old cats are usually still worth some money) and when the cat reaches running temp then a chemical reaction takes place between the metals and the exhaust gases which converts most of the harmful gases to less harmful products.
BUMPTJ
The Parts Man
ok by deanojul67 on Thu Feb 14, 2008 3:59 pm
Dean'o
or kept the pajero
deanojul67
