Frontera Technical Support • View topic - Anyone know where EDC is on 2.5 TD?
Anyone know where EDC is on 2.5 TD? by JBW on Tue Feb 05, 2008 9:42 am
JBW
Model: 2.5 TDS Transglobe 5dr
Modifications: Standard
by Red Oktober on Tue Feb 05, 2008 9:59 am
are you on about the ECU (Engine Control Unit)
i'm possitive i read somewhere on here that it's uder the passenger side carpet at the front...
by huggy on Tue Feb 05, 2008 5:47 pm
huggy
by Red Oktober on Tue Feb 05, 2008 5:49 pm
by paul higgi on Tue Feb 05, 2008 7:21 pm
paul higgi
3" body lift
5;38 diffs front /rear
ARB compressor
Superwinch EPI 9
Revolution transfer gears
Cb
Surco roof rack
4 x spotlamps
Rear spotlamp
Rear tubular bumper
Isuzu trooper rear axle
Isuzu trooper front axle
Safari snorkel / RHS SS25HF
Arches cut and welded
trooper transfer case housing
Hydraulic handbrake
AVM manual locking hubs
3" Flexi Arch Kit
by JBW on Wed Feb 06, 2008 9:35 am
It's referenced in the Haynes manual as the EDC - Electronic Diesel Control Unit - so I guess the function of the ECU would be the same?! I note that there are a few relays to the LHS of the passenger footwell behind the plastic cover. Can't see anything with the number of connections that the EDC/ECU would have down there.
Why on earth do the Heater Fan Motor relay control 12V/0V come from this unit? Logic escapes me.
Anyhow thks for feedback - I'll go hunting for it this weekend..JB
JBW
by Red Oktober on Wed Feb 06, 2008 9:58 am
it's actually under the carpet ........
there is a pic on here somewhere ... :wink:
by Red Oktober on Wed Feb 06, 2008 9:59 am
think it was Paul Higgi who found his under the carpet ....
could you confirm this Paul ....please :D
by john (smifffy) on Wed Feb 06, 2008 10:13 am
by Red Oktober on Wed Feb 06, 2008 10:16 am
by jjcymru on Wed Feb 06, 2008 1:39 pm
jjcymru
by JBW on Wed Feb 06, 2008 10:18 pm
Ah jj. Good reply. Just seems overly complicated when it could have simply come from the switched side of the ignition switch.
Had a nose under the carpet on the passenger side, couldn't see any ECU gubbins with a torch tonight!!!
Is it in a cut out in the floor? Being a bloke, if it doesn't jump out at me and shout I don't see it! :wink:
JB
JBW
by huggy on Thu Feb 07, 2008 2:52 am
ye its a plate where the floor tows up under the dash,2 screws :wink:
huggy
by paul higgi on Thu Feb 07, 2008 7:00 pm
paul higgi
3" body lift
ARB compressor
Superwinch EPI 9
Cb
Surco roof rack
4 x spotlamps
Rear spotlamp
Rear tubular bumper
Hydraulic handbrake
3" Flexi Arch Kit
by JBW on Sat Feb 09, 2008 9:35 pm
Isn't it great how much progress you can make gioven a warmish dry bright day.
Persisted in hunt for ECU and as advised there the shiny little bugger was hiding in the foot well.
All checked and put back together - problem isolated to circuit supplying the Air Con which is a spur off the supply the the fan. So I've pulled a 20A fuse in the cabin and relay K80 RHS footwell , green 4 pin.
Fan works fine now. Will save investigation on AC wiring for longer daylight hours.
Thanks for all your assistance on this.
I took some pics that I can upload if someone can post instructions or I can email them to a moderator?
Ta. JB.
JBW
