Frontera Technical Support • View topic - my clutch i think is away on disco
my clutch i think is away on disco by dave-mr2-frontera on Sat Jan 26, 2008 8:09 pm
dave-mr2-frontera
by I Live For FOG on Sat Jan 26, 2008 8:33 pm
easy bulkhead flexing or dirty clutch fluid
the bulkhead probably needs welding
A legend in my own mind
I Live For FOG
by Drift on Sat Jan 26, 2008 8:59 pm
First as Steve said bleed the system, then check under the clutch pedal you will see a rod that goes through the bulk head, on the pedal end off this you will see a bolt this is adjustable and has another nut on that is lockable, this alters the pedal hieght. :wink:
Re: my clutch i think is away on disco by di on Sat Jan 26, 2008 9:06 pm
di
by Drift on Sat Jan 26, 2008 9:08 pm
by Truckosaurs on Sat Jan 26, 2008 9:12 pm
Truckosaurs
by dave-mr2-frontera on Sun Jan 27, 2008 3:16 pm
i have bleed the sytem and fixed it a bit but i think air is getting in through the slave cilender ? we should have a speel check on this lol :lol:
dave-mr2-frontera
by andysd1 on Sun Jan 27, 2008 3:40 pm
by I Live For FOG on Sun Jan 27, 2008 6:53 pm
I Live For FOG
Re: my clutch i think is away on disco by judderman3000 on Thu May 13, 2010 11:53 am
i have the same thing on my Frontera Sport A 2.8tdi but its slightly better if i pump the pedal?
does this suggest fluid to you all? and maybe slave/master cylinder? iv never touched a hydraulic clutch before so any help appreciated! i used to be an SJ man! before i saw the light
this is very embarassing iv come to check the resevoir to find its as good as empty, could this mean fluid is escaping somewhere? the clutch feels much better after putting more fluid in but its still not right
any help greatly appreciated
judderman3000
Modifications: 2" Coil Spacers + Torsion bar lift
Removed Front Bumper
Moved Rear Lights
Re: my clutch i think is away on disco by Drift on Thu May 13, 2010 4:52 pm
It may have a leak so keep an eye on it, it will need bleeding too.
Re: my clutch i think is away on disco by 4x4 bobby on Thu May 13, 2010 5:03 pm
Dave if its a Disco best solution is take it to breakers and then buy yourself a Frontera!!!!!!!!!!!!!
