Frontera Technical Support • View topic - Frontera gear problems
Frontera gear problems by Davef on Fri Jan 25, 2008 10:50 pm
alrite peeps,
just try'd posting the help bit but need to be a mod to do a new topic,
i got my self a frontera today and drove it back it was sound as a pound, i got home parked up for 30mins, went back out for a drive in my new car. all seem great i make a wrong turn, had to revise up a hill when i got back to top tryed selecting 1st and it wouldn't go any where, just a simple nudge forward and stopping, tryed again thinking it wasn't in gear and did the same am able to push the car and it moves freely, so i know it can't be a the diff. :(
just wanted to know if you point me to the right way for the fault(s) and to get back on the road and enjoy my frontera. :D
thanks looking
Dave
Davef
by Drift on Fri Jan 25, 2008 10:52 pm
What model and year is it ?
Is the little hi/lo lever in 2H position ?
by Red Oktober on Fri Jan 25, 2008 10:58 pm
make sure the little lever is in 2H
Welcome to FOG :D
by Davef on Fri Jan 25, 2008 11:18 pm
hi yeah the little gear stick is in 2 h, and its a l reg 1993 2.3 turbo diesel!
Davef
by Drift on Fri Jan 25, 2008 11:23 pm
by Davef on Fri Jan 25, 2008 11:33 pm
Davef
by Red Oktober on Fri Jan 25, 2008 11:43 pm
by shez on Sat Jan 26, 2008 9:21 am
if it was the master cyl or the slave cyl, wouldnt he have problems getting it into gear? as opposed to not moving when in gear :?:
Kris
shez
by Davef on Sat Jan 26, 2008 12:40 pm
Davef
by I Live For FOG on Sat Jan 26, 2008 1:26 pm
A legend in my own mind
I Live For FOG
by Red Oktober on Sat Jan 26, 2008 1:29 pm
by I Live For FOG on Sat Jan 26, 2008 1:37 pm
Last edited by I Live For FOG on Sat Jan 26, 2008 2:42 pm, edited 1 time in total.
I Live For FOG
by barryc28 on Sat Jan 26, 2008 2:07 pm
Fronty2
2.8tdi n plate swb
white
flappy paddles removed
Es9000 +2 shockers
barryc28
by Davef on Sat Jan 26, 2008 2:50 pm
Davef
by Davef on Mon Feb 11, 2008 10:56 pm
hi there thanks for the help but ive decided to take to the garage and they have striped it all down and they have rung me today to say the clutch id fine but it as a dual fly wheel on which has collapsed or something like that. Which i didnt know it would have one of these on but it can mended they said they can change it to a normal fly wheel, and i wouldnt know any difference in the change cos they carnt get hold of dual fly wheels any longer. Is this a good or bad idea let me know your comments! Also can fly wheels be rebuilt?
Cheers Dave
Davef
by I Live For FOG on Mon Feb 11, 2008 11:12 pm
flywheelpart number 90446938 never heeard of dual mass on a 2.3diesel
clutch has been done on one recently on forum
can you get them to keep it for you we have a reconditioner for 2.8 dual mass flywheels
I Live For FOG
by Davef on Mon Feb 11, 2008 11:24 pm
ya ill go get it to moz. so wat do u think they pullin one over me?
Davef
by I Live For FOG on Mon Feb 11, 2008 11:26 pm
we are under the impression dual mass was only introduced 1995 on 2.8 tdi
you need to see flywheel
is it local to you
I Live For FOG
by NugSport on Mon Feb 11, 2008 11:27 pm
dual mass on a 2.3d hmm odd, with a dual fly you gain the smoothness & vibration dampening characteristics than with a conventional solid fly, the solid fly's are much more affordable and robust though, I do know that they do fit the dual mass application on some vehicle's to gain the option of wider clutch plate diameter to raise up the torque capacity of the drive train. i have done many a clutch change and i have gone from dual to a solid fly.
the dual fly can also be re surfaced as well matey, if they remove the bolts and separate the primary and secondary flywheel.
2.4i LWB 93
Regards
Steve.
NugSport
Modifications: Dual screen lexus DVD/MP3 player, Uniden Uniace 200 CB,
by Davef on Mon Feb 11, 2008 11:47 pm
Thanks for that steve. ya its down the road from me.
Davef
