Frontera Technical Support • View topic - Voltage drop
Voltage drop
Voltage drop by Shayne Farwell on Fri Jan 11, 2008 6:29 pm
Shayne Farwell
by Sir-Doris on Fri Jan 11, 2008 7:14 pm
by Shayne Farwell on Fri Jan 11, 2008 7:42 pm
Shayne Farwell
by I Live For FOG on Fri Jan 11, 2008 7:44 pm
A legend in my own mind
I Live For FOG
by Shayne Farwell on Fri Jan 11, 2008 7:56 pm
Shayne Farwell
by meooo on Fri Jan 11, 2008 9:34 pm
meooo
Cookie monster
Cookie monster
Vehicle Name: dead
Still sporting Salisbury mud
Gone to meet its maker :(
Skype Username: john.hird8
by john boy on Sat Jan 12, 2008 9:16 am
You need a multimeter with amps on 10A min. take off earth lead and connect earth to earth pole on battery and positive to earth lead and make sure igy off and key out before starting, best if truck locked. check drain if its a digital unit should read about 0.08A with no consumers on. if its up around 0.12A you've got a high draw, start removing fuses and watch to see if drops. when it drops you've found your draw. i haven't used the volteage check but i do use this method at work and it works most times just make sure that the meter is fused should say 10-20A max.
by I Live For FOG on Sat Jan 12, 2008 9:26 am
shayne put area of country in profile please someoine may have tools you need and might know how to fix it in your area
I Live For FOG
by john boy on Sat Jan 12, 2008 10:23 am
Multimeter can be purchased from machine mart for about £40+vat and does a load of other things as well this it's a very handy piece of kit to have in your tool box
by I Live For FOG on Sat Jan 12, 2008 12:10 pm
I Live For FOG
by john boy on Sat Jan 12, 2008 5:22 pm
Spotted that in the maplins book but can not see if it's fused realy needs to be fused cause if not can cause a lot of greif and heart ache cause if it aint protected and you get to much draw will burn out meter i know 10A's is a lot of draw but if it's a diesel and glow plug relay stuck in you could be drawing upto 40A and i have known this to happen don't half give you a shock when leads start to melt :shock: :shock:
by I Live For FOG on Sat Jan 12, 2008 7:30 pm
I Live For FOG
by nitromotor on Sat Jan 12, 2008 7:51 pm
by Shayne Farwell on Sat Jan 12, 2008 8:05 pm
Shayne Farwell
by Shayne Farwell on Sat Jan 12, 2008 8:17 pm
Shayne Farwell
by comfortablyglum on Sat Jan 12, 2008 9:59 pm
comfortablyglum
by Shayne Farwell on Sat Jan 12, 2008 11:28 pm
Shayne Farwell
by comfortablyglum on Sun Jan 13, 2008 2:24 pm
Chickens still there, though in greatly reduced numbers. Mainly a batchelor pad of cockerels, very few hens there.
Currently with a 2.3td 5dr, slow, noisy, smokes a lot, and I love it. Girlfriend wondered what I was going to get next as Fronty out of MOT soon. Told her I didn't need a change of vehicle,(Must be something to this fronty lark as I never said that before!!)
comfortablyglum
by Shayne Farwell on Mon Jan 14, 2008 9:39 pm
Shayne Farwell
by Rick on Mon Jan 14, 2008 10:00 pm
2001 Discovery ES TD5 (EGR Bypass, De CAT, General Grabber AT2 Rubber)
2000 Fronty SWB RS 2.2 Petrol (LSD Model)......RIP
Insa Turbo Sahara Boots
Maycom EM-27 CB
SS100HF Safari Snorkel
3" Lift (LA Supertrux)
200BHP MGF and '04 MGZR 160
Rick
Modifications: 3" Lift, Safari Snorkel, CB, Insa Turbo Sahara M/T's
