Frontera Technical Support • View topic - still cant get this. (new owner fog)(please help asap(
dave-mr2-frontera
by dave-mr2-frontera on Wed Dec 26, 2007 8:26 pm
dave-mr2-frontera
by Trugga on Wed Dec 26, 2007 8:46 pm
There should be one snap ring and one washer.
by dave-mr2-frontera on Wed Dec 26, 2007 9:15 pm
dave-mr2-frontera
by Red Oktober on Wed Dec 26, 2007 9:17 pm
by Trugga on Wed Dec 26, 2007 9:28 pm
"muddypluka"'s photo
Once you've removed the 6 bolts and the end cap (and the outer body) the snap ring and washer is the next thing you need to remove in order to remove the mechanism.
by marlbororman on Wed Dec 26, 2007 10:21 pm
If you cant see the groove where the circlip fits into, try getting a mate to push the shaft inwards through the wheel from behind the hub, it makes it a little easier, coz when trying to get the clip on, you tend to push on the shaft. :lol:
Member no. 705
marlbororman
by dave-mr2-frontera on Fri Dec 28, 2007 1:37 pm
ace you boys no your stuff! right do you know the size of the circlip and snap ring that i need to get from vauxhall as there are 10 diffrent sizes(so they said) and there are none in stock i have tride to push the drift shaft through but it just going flush so i cant get the circlip on even if i had one :( think i will have to get a little more elbo greese into it me thinks :roll:
dave-mr2-frontera
by I Live For FOG on Fri Dec 28, 2007 1:44 pm
A legend in my own mind
I Live For FOG
by dave-mr2-frontera on Fri Dec 28, 2007 1:56 pm
have done mate but its a wee bit breif for me am not used to 4wd at all i used to have a mr2 rev 3 turbo lol. well still got it just need new piston rings lol. i just dont now were the washer and circlip goes. i know it goes at the end of the drive shaft but i dont now the size of the washer and circlip to put back on as vauxhall need a size as there are 10 different once. :roll: mine have vanished dont know how i could have gone its a sealed unit but no mater
dave-mr2-frontera
by I Live For FOG on Fri Dec 28, 2007 2:48 pm
I Live For FOG
by dave-mr2-frontera on Fri Dec 28, 2007 8:30 pm
alright mate ceers for that i phone they vauxhall dealers and they have any in stock lol ust my luck eh so back to breakers the morn bril but will get there in the end
dave-mr2-frontera
by Trugga on Fri Dec 28, 2007 9:49 pm
I've got two new (unused) ones here (that I no longer need)
PM me your postal address and I'll mail 'em up to you.
I lost one origonal, so bought my local VX dealers entire stock (the three shown above) - but I only ever needed 1 (I now have manual hubs with a different size circlip so these are suplus to requirements)
Feel free to make a donation to FOG
by shinyheed on Sat Dec 29, 2007 10:31 am
or get around this problem how i did
screw a bolt into the end of the drive shaft and tack weld it in place, cut its head off so its just threaded bar, then assemble all the hub
find a washer just larger than the hole you can see the drive shaft in
put that washer on and then and then put a nut on the threaded bar sticking thru the washer, gently tighten the nut to put the drive shaft into position in the hub (do not over tighten, just needs to be finger tight)
then tack the washer to the hub, and the nut to the washer (just tack weld tho so when you need to get it off a long bar and socket will break the weld)
we did this on my old sport as it kept having the circlip come off the end of the shaft when i used 4wd in anger
i'd wished i'd done it earlier as it fixed the problem completely
the washer sat where i've highlighted red
(my hubs had the springs removed so they were permanently engaged so i never had a hub slip, this may not work with the autolock springs fitted, i'm sure it would work but i've not got mine to look at to check so check first)
Phil, member of http://www.northtyne4x4.com and http://www.4x4responsenortheast.co.uk
i turned to the dark side but i miss my killed in action fronty
shinyheed
by Trugga on Sat Dec 29, 2007 11:34 am
Be aware that the end of drive shaft snap rings should be replaced once removed, as they do stretch (making them loose when refitting)
The following picture shows new snap rings above and old (removed and replaced a couple of times) below:
by alex on Sat Dec 29, 2007 7:09 pm
I just got a selection of circlips from halfrauds and fitted the best match. made re-fitting easier as I could use circlip pliers.
by dave-mr2-frontera on Sat Dec 29, 2007 7:46 pm
dave-mr2-frontera
by shinyheed on Sat Dec 29, 2007 8:49 pm
shinyheed
by dave-mr2-frontera on Sat Dec 29, 2007 8:57 pm
dave-mr2-frontera
by Trugga on Sat Dec 29, 2007 8:59 pm
