Frontera Technical Support • View topic - how do i fix a fuel leak (diesel)
how do i fix a fuel leak (diesel) by sare^baw's on Wed Dec 12, 2007 3:37 pm
sare^baw's
by outergods on Wed Dec 12, 2007 5:35 pm
Ive replaced the rear sections of the 3 fuel lines on mine with rated diesel hose. Rather than trying to find the leak, just chop out the section where you suspect it to be and replace with proper fuel hose.
using a flairing kit to flair the ends of the remailing pip and good clips will see you right.
Matt
2.8TDI Sport. - 3" lift, 31" Recip Trials, Roof Rack, High Lift, Winch.
outergods
by sare^baw's on Wed Dec 12, 2007 6:18 pm
sare^baw's
by outergods on Wed Dec 12, 2007 6:52 pm
outergods
by sare^baw's on Wed Dec 12, 2007 7:24 pm
sare^baw's
by cipher on Wed Dec 12, 2007 8:10 pm
cipher
Modifications: none yet :)
by sare^baw's on Wed Dec 12, 2007 8:55 pm
sare^baw's
by cipher on Thu Dec 13, 2007 4:18 am
right i had a look at some of the past posts and its 2 lengths of 8mm pipe and 1 6mm pipe, also dont do this job unless there is alot less than half a tank in it or it will spew all over the place lol.
cipher
by sare^baw's on Thu Dec 13, 2007 11:59 am
sare^baw's
by outergods on Thu Dec 13, 2007 1:24 pm
Tie wraps and thoughtful routing. :)
partco will sell flaring tools too. cheap ones for about 15 - 20 quid will do, but are a bugger to use. Expensive ones are great, but not worth the cash if you are just doing the odd job.
I got a tool from Machine mart for around 20 quid. its not the best, but it works for brake lines and fuel pipe :)
matt
outergods
by sare^baw's on Thu Dec 13, 2007 2:53 pm
sare^baw's
by outergods on Thu Dec 13, 2007 2:59 pm
outergods
by sare^baw's on Thu Dec 13, 2007 3:19 pm
sare^baw's
by sare^baw's on Thu Dec 13, 2007 5:19 pm
sare^baw's
by sare^baw's on Fri Dec 14, 2007 11:11 am
sare^baw's
