Frontera Technical Support • View topic - overheating
overheating
overheating by Silver Ghost on Mon Dec 10, 2007 10:02 pm
Hoping for some advice before morning, as i will have to put my truck in the garage. i have a 1994 2l sport
Went to pick my wife up from the coach station after work, the journey there was trouble free.
I went for a coffee and returned to my truck to wait for her coach. switched on the engine, the windows appered to be more misty than usual and took longer to clear.
I put on my heaters, and after a short while they still felt cold. the temp guage had started to rise and was just past first white mark. ( my engine normally never goes past this mark in normal running conditions).
so i fiddled about abit the controls, and found that the footwell heater was cold, when i switched controls to demist, this was warm, (normal temp).
driving home, when i came to traffic lights, or stationary traffic, the temp started to rise to second white mark. when i started to move again, i was only really able to maintain the temp from rising with demist and fan on full. where normally the temp would fall if it ever got this high after a couple hundred yards.
Now my question is, would this be thermostat as i still had heat on the demist but not the footwell.
Secondly question, is it possible, blocked heater matrix, as i have heat at the dimist, but not footwell. and would this cause engine temp to rise quicker than normal.
or do i have something bigger wrong.
regards
sean
Silver Ghost
Registration Year: 1999/S
by rangaKoo on Mon Dec 10, 2007 10:59 pm
I know it sounds really daft and probably very obvious, but does the reservoir have water in it up to the proper point? (believe me, I've seen people who have no clue!)
switching between footwell and demist should affect anything unless one of the levers somewhere is trapping a pipe, however the pipes are rather strong rubber and not likely to become trapped by anything.
Your thermostat could be playing up, or perhaps one of the rad pipes may be blocked, your probably best of flushing out your radiator and seeing if it's full of stuff.
I'm sure some more suggestions may be made shortly.
I'm having a bad forum night, accidentally breaking stuff so I might go to bed ;)
rangaKoo
by Silver Ghost on Tue Dec 11, 2007 8:06 pm
Silver Ghost
by john (smifffy) on Tue Dec 11, 2007 10:40 pm
by Wneiljohnson47 on Wed Dec 12, 2007 7:44 am
This might help and its a bit cheaper :D :D
http://cgi.ebay.co.uk/VAUXHALL-FRONTERA ... dZViewItem
"metallic brown" 2.2eco LWB "A"1999 & Black 2.2DTi LWB "B"2003
the way forward is back the way you came
Wneiljohnson47
