Frontera Technical Support • View topic - Frontera B, petrol, 4x4 vacuum system
Frontera B, petrol, 4x4 vacuum system by SIMON MCCORKINDALE on Mon Dec 03, 2007 5:35 pm
SIMON MCCORKINDALE
by marlbororman on Tue Dec 04, 2007 11:03 am
whats the problem you got, coz i doubt if they are at fault? have you tested them?
Member no. 705
marlbororman
by marlbororman on Tue Dec 04, 2007 11:11 am
Member no. 705
marlbororman
Member no. 705
marlbororman
by marlbororman on Tue Dec 04, 2007 11:17 am
The bottom diagram is of the 2 to 4x4 shift motor, its underneath,on back of transfer box. it turned out to be faulty on mine. The vsv valves, if you connect up as in the diagram, and check by blowing down the tubes, to see if its switching over correctly, but id put money on the transfer motor assembly, they dont take to kindly to getting soaked and then not been used for long periods of time... Mine tested ok in my hand but wouldnt work in situ. so check it while fitted to the fronty too. Bet tthe valves are ok, let me know if you need anymore help. Know the 4x4 system like back of my hand now, after my problems.
Member no. 705
marlbororman
by SIMON MCCORKINDALE on Mon Dec 10, 2007 10:38 am
SIMON MCCORKINDALE
by marlbororman on Mon Dec 10, 2007 9:05 pm
pleased you got it sorted, can be real pain to find faults on our 4x4 system...been there done that :lol: :lol:
Member no. 705
marlbororman
