Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Fri Mar 09, 2012 3:20 pm
Nothing too major, pulled the instrument cluster out and changed the bulb for the handbrake ON/brake fluid level warning light, simples :D . Got to pluck courage to change the steering idler now, mines got a little play in the bushes :( .
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Mar 09, 2012 7:00 pm
sprayed my nut's :oops: with WD40 ready for the 2" suspension lift tomorrow on the 2.5 :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Mar 09, 2012 7:05 pm
No squeaking bed then :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri Mar 09, 2012 7:54 pm
found replacement universal 02 sensors for my truck for £15 notes each and from the next village made me laugh after looking at £109+ from local motor factors. http://performancepartsauto.co.uk/Oxygen_O2_Lambda_Sensor_4_Wire_Universal.html
laid underneath and got sensors ready for removal pulled the cable off and decided to let it run for a while to run some of the injector cleaner to run through while it is sat there and it ran quite well for about 20 mins before stalled and then when i went to fire it back up would not fire as it was flooding itself and then a nice little bang as the maf sensor ignited the fuel vapor coming out the carbs into the air box.
here is the honeycomb
that used to live here on the front of the maf sensor lol
maf is still working so going to have to nip down the pound shop for a metal tea strainer to replace the honeycomb using the mesh
god loves a redneck repair :dance: :dance: :dance:
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 09, 2012 8:04 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Mar 09, 2012 8:12 pm
Dean, do a write up it could help others :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri Mar 09, 2012 8:18 pm
will do when i get the 02 sensors as its just a case of cuting the plug off the old one and crimping the new on the end of the similar colored wires.
will do one of the maf repair as looking for the honeycomb but as it is only to keep the any bit particles that get through the air box out i think the tea strainer mesh should do fine. :thumbup: :thumbup: will know more one i get round to it over the weekend
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Mar 09, 2012 8:21 pm
Cheers Dean :thumbup: :thumbup: :clap:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri Mar 09, 2012 8:30 pm
still cant believe how cheap they are £15 a peice for the 4 and cheaper for the 3 and 2 and 1 wire versions small local firms cant beat them.
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Fri Mar 09, 2012 8:42 pm
no need to refit the mesh dean. but yeh the universal lambdas are ace the main cos are the plugs. as for my truck ive put more fuel in it. so much for 2.2's being unreliable :P
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 09, 2012 9:09 pm
lol no i didnt after looking at it in day light :shock: but i started it after fitting a new (to me) battery to check the battery could turn it over as its only a 650cca and the old 1 was a 750cca and oil light went out straight away :). That said the battery did come out of a 3 litre straight 6 volvo so shouldnt really strugle with a 4 pot 2.2
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Fri Mar 09, 2012 10:27 pm
Got the cylinder head off and in the boot of the car, Will have a good like in the daylight tomorrow but it had definitly gone on number 1 cylinder. Nice to finaly meet you Frank (Snapper)
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Pumped up my slow puncture again and decided that tomorrow after work I'll change front and rear diff oils my fuel filter and borrow a grease gun and grease some nipples, I might while I'm down there extend the diff breathers. :D
All this if I can pick up a spanner, damaged a tendon in my hand Wednesday and not liking the pain happily shares with me :(
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Mar 09, 2012 11:34 pm
Your lucky if you can get everything next to you as you can stay lying down when you do it :think: :lol:
That should be possible the hard parts gonna be working spak handed. :evil:
Only I could damage my right hand and be right handed :roll:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 10, 2012 12:00 am
I am lucky then being left handed :dance:
:roll: there's always one.
Your welcome to come down to some warmer weather for an hour or two to do it for me? :D
Or I could see if the mrs will do it for me??????
Hmmm nope doubt that will happen :thumbdown:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 10, 2012 1:33 am
:lol: :lol: If the fuel was cheaper I would be there :thumbup:
Bring back the 90's :shock: :lol: :shock:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Mar 10, 2012 2:05 pm
today i mounted my winch :dance:
pic's etc to follow soon
