I realised that my front right outer cv joint had split, and by split I mean in two, and caked everywhere in cv grease! Gonna have to do both boots on the outside as I found out they the original ones from the factory! :shock: :shock: :evil:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Feb 26, 2012 9:03 pm
Quite therapeutic sitting on a tyre doing CV boots, just the grease gets every where :lol:
Yeah we shall see how short a temper I got too trying to undo ball joint bolts :evil:
Or any other bolt that won't move with a six foot breaker bar on it :roll:
The grease I can cope with, makes sure nothing's gonna rust :lol:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Feb 26, 2012 9:43 pm
Use a split boot, half an hour and you only need take the wheel off :thumbup:
Split boot?
They any good? Last one I tried just turned out to be a mess and waste of money.
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Feb 26, 2012 9:55 pm
Ive had them last a few years and that with many a rough laning day :wink:
Just by chance have you got a link to the ones you use?
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Feb 26, 2012 10:09 pm
I used ebay, cheapest I could find
Ok nice one I'll have a nosey and let you know what happens. :)
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Feb 26, 2012 11:17 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Feb 26, 2012 11:35 pm
:lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Feb 27, 2012 7:37 pm
today i got a nice package arrive at my work bench
had it was my front monroe shocks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Mon Feb 27, 2012 9:59 pm
Started up for the first time in about 6 weeks - started first time :D Found the rear o/side window has been leaking and the boot space carpet has soaked up few gallons of water, making it a bit pongy :evil:
Lifted the carpet and thankfully the floor of the car is rust free, just needs drying out.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Feb 28, 2012 10:47 pm
Broke my drivers window. Won't wind up or down. I reckon 22 year old electrics are at fault.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Feb 28, 2012 10:51 pm
Replaced coolant hose to turbo.
Adjusted valve clearances - doesn't sound like nuts and bolts being shaken in a can now!
Adjusted rear shoes
Removed what was left of the rear brake disc guards
Unblocked and re positioned rear diff breather
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Feb 28, 2012 11:18 pm
That last one saved you a whole world of pain boxy.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Feb 29, 2012 4:41 pm
me & vauxsqueeks ripped the heart (engine) out of Christine
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Feb 29, 2012 4:46 pm
I have just finished upper and lower ball joints cv boots and cv joints on drivers side. :dance:
and now to do the other side :shock:
Once i done that im not going near another joint for the rest of my life!!!
i got the joints for £20 each new :D from http://stores.ebay.co.uk/J-R-CV-JOINTS- ... 4340.l2563
and i could collect from them saving on postage 8)
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by taylor6632 on Wed Feb 29, 2012 8:08 pm
went to change brake pads. found out old ones still have a third left so put the wheels back on. should've checked more closely but oh well, got a spare set now.
taylor6632
