Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Feb 17, 2012 1:18 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Feb 17, 2012 7:43 pm
today me and fogman removed my door and front wind to sort out one of the hinges and then the fun started trying to get the door lined up
took us about 3h to sort the door
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Feb 17, 2012 8:00 pm
on the 2.5 replaced some of the water pipes then flushed the radiator only topped up with water until i get the new pipe off BoxCleva.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Feb 17, 2012 8:37 pm
You have PM Andy.
Spent the day ( 9.15 - 6.30pm) helping Dave fit an injection pump to a 2.5. Not as straight forward as it would appear!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Feb 17, 2012 9:11 pm
Got a new pressie :twisted: :twisted: :twisted:
viewtopic.php?f=32&t=48458
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Feb 18, 2012 12:16 am
still hated
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Sat Feb 18, 2012 12:49 am
Changed oil in gearbox
Carried on cleaning rear diff
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Feb 18, 2012 9:27 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Feb 18, 2012 1:43 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jonnyjeep on Sat Feb 18, 2012 3:19 pm
started out with fitting glow plugs but also toik off cold start, egrs,removed birds nest, fixed cracked bulkhead at clutch pedal and fitted new clutch master cylinder. I have been a busy little beaver havnt I :lol: :lol: :lol:
jonnyjeep
Vehicle Name: project20
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Feb 18, 2012 4:22 pm
Well done Jonny.
As for me nothing on the truck, however pre mot on the Arsetra proved daunting ... low brake performance on the rear, jammed bias valve, and rusty brake pipes. Cleaned the brake pipes, freed off the bias valve, cleaned the drums, lets hope it passes next week :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Feb 18, 2012 5:00 pm
Inspired by Ratty and his wheel arches I thought it was about time I got into the shed and got my flexi arches cut out and manipulated :D
I am fed up of not being able to see out the windows when laning or off road as the tyres fling up so much crap.
A bit of cutting.
A bit of sanding to smooth the edges,
A stand back and look moment
Now they are all cleaned up (bloody rubber dust everywhere :roll:
I will fit them to the truck when the wind calms down.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Sat Feb 18, 2012 5:25 pm
actually got around to doing my lwb light conversion :D
paul01
Vehicle Name: ?
Modifications: none
yet :)
At present I'm halfway through taking the egr valve off and cleaning it.
Just gotta replace the rubber seal as I slit it while persuading the valve off with a handful of screwdrivers and a mallet. :)
Should re assemble really :roll:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Feb 18, 2012 8:10 pm
i sent all day working on the cars (Christine & Bob) swapped the front bumpers over and the spot lights, fitted the dvd player head unit, fitted the C.B, removed the rear light guards (now on ebay) replaced the leak off pipe's on Bob. then started stripping Christine :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Feb 18, 2012 8:15 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Feb 18, 2012 8:17 pm
today i picked up my new LSD axle and the shocks and after closer look they are monroe shocks so will be putting thoes on mine sooner than later
and then picked up a set of wheels i have been asked to sell.
so not too bad of a day
ohh and nearly lost my trailer again, defo now need a new tyre for it :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sat Feb 18, 2012 8:31 pm
Drove to Sheffield to collect my new muds and wheels. Stopped off at a nice hotel to save driving back till tomorrow.Truck behave very well started much better. Will see how good it is in the cold tomorrow.
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sat Feb 18, 2012 9:32 pm
Took mine for a drive after over hauling the cooling system (new matrix, new radiator and thermostat) now gets toasty and warm (had to turn it down) also doesn't sound like a bag of nails as it now gets to operating temp (old thermostat stuck open).
Yes a 2.8 with heat :shock: :lol:
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Feb 19, 2012 2:48 pm
so far today i have removed the roof rack off the 2.2 and fitted it to the 2.5. not wired up the roof lights yet.
then removed the body lift and the suspension lift off the 2.2
now food then i'll carry on removing bit's. :D
