Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Feb 01, 2012 9:20 am
Fingers crossed Dan... :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Feb 01, 2012 1:46 pm
Well the battery seems fine again :D
Well it failed the mot...
He then fitted a new o/s front side light (f-ing thing worked yesterday) and asked me to remove my phone mount off the windscreen and then he passed it :-D :drink:
Got a load of advisorys tho...
Both front indicators slightly discoloured
N/s front anti roll bar rubber bush deteriorated but not resulting in excessive movement - even tho they are the orange poli bushes...:/
O/s rear arb rubber bush...same as above :/
Both rear arb linkages have some play - well i knew that anyways
N/s front bearing has some play...not a problem
Oh and this 1 i wouldnt of said was a advisory...more of a reasurence lol
Under-trays fitted obscuring some underside components :roll:
All in all not bad for the millage and abuse she gets...currently showing 168k on the clock. Only had 132k when i got her lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Feb 01, 2012 1:48 pm
Oh on the smoke test, whats FPT? It got 1.49 and the max allowed is 1.5 so only just passed that :S
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Feb 01, 2012 2:33 pm
Well done Dan ... That old girl just keeps on giving. I am truely amazed how well she does.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Wed Feb 01, 2012 9:11 pm
Took delivery of my new clutch and heater matrix. Just gotta figure out how to get them fitted now :roll:
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Feb 01, 2012 9:39 pm
Spent allllllllllllllllll day in -2 degrees fitting a snorkel to Dave's 2.5.
Still bloody freezing even now! Snorkel looks good to be fair considering it still needs finishing off. Total cost I reckon is about 5 drill bits (Dave has a habit of breaking them) and some duck tape to protect the body :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Wed Feb 01, 2012 10:28 pm
ive never said it before
just had to say it
:ttiwwp:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Feb 01, 2012 11:18 pm
learned that i dont have any reverse lights explains why they dont work and learned 2.8s have crap heaters
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Feb 01, 2012 11:55 pm
Eh ... you sure ... I have reverse lights and my 2.8 heater works fine ... especially after I relpaced the thermostat. Mind I have been changing the coolant and properly flushing the crud out of the system every 4 months or so.
Reverse Lights (same both sides):
Heater:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Thu Feb 02, 2012 12:59 am
Someone dug something up ages ago about there being an upgraded heater matrix available for the 2.8, but VX would only fit it if the warranty holder made a complaint about the heater being rubbish. Some of them may well have been upgraded (mine defo wasn't though, until now) :)
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Feb 02, 2012 1:04 am
i looked when it was dark maybe why i didnt see them have a look in day light i really havent had a wander round in the light yet.
The guage doesnt move much stays in cold drive up was decent but local its crap i will try flush system and new thermo might help when i do filter n oil
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Thu Feb 02, 2012 8:49 am
here you go drinks
viewtopic.php?f=21&t=48067
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Feb 02, 2012 12:18 pm
And the correct drain plug to remove:
viewtopic.php?f=21&t=48068
Give her a good old flush out. Don't forget you have 2 matrixes ... one under the passenger front seat as well. Though I ignore that one :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Feb 02, 2012 4:21 pm
glad you mentioned that one .thanks for the links guys.
I have one reverse light on the passenger side doesnt work but least i have one
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Feb 02, 2012 4:34 pm
Thats funny as I have 2 reverse lights ... both work. Curious as they are the same truck. All I can think is someone changed one lense for a non-bighorn cluster at some point which has the reverse lights in a cluster in the bumper. Bighorns (import) don't have bumper lights. Much like the situation you have with SWB and LWB Series A Fronteras.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Feb 02, 2012 4:46 pm
That as high as my temp guage goes, Might be a possiblty about lens unless that been replaced with a fog light
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Feb 02, 2012 5:29 pm
That would figure. Good modification that. Replace one lens from a UK model and convert it to a rear fog light.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Feb 02, 2012 7:08 pm
Monterey
Drained and refilled Gearbox oil - (I can only assume that the person who last changed the gearbox oil was a 25 stone Gorilla who used a 6ft breaker bar to tighten the plug. Bloody hell that was tight :evil: )
Drained and refilled Transfer box
Fitted 85c thermostat
Filled all grease nipples
Adjusted new alty belt
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Feb 02, 2012 7:41 pm
some page that troopers and monterys.
I went outside there an tried fog light once found switch, The light on dash which is look like a after thought orange light above dials it lights up but no fogs i will check in morning see if there is a bulb in there too effing cold out there
Users browsing this forum: No registered users and 52 guests
