Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frontycustoms on Wed May 20, 2009 10:10 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MuddyD on Wed May 20, 2009 10:14 pm
24 beers in a case, 24 hrs in a day...... coincidence ???
MuddyD
Modifications: None as yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Wed May 20, 2009 10:29 pm
31" rubber will go on without lift Dave.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Wed May 20, 2009 10:51 pm
Today I let the misses drive it..................
she ain't going to drive it again....
and I aint going to be a passenger if she changes her mind. :!:
(edit)
she once worked for a car auction place, and wrote off a tvr when she was taking it in to the hall.
(mind you, it had no brakes) but thats no excuse.
her answer was, " it is made out of plastic so what did you expect?"
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Thu May 21, 2009 8:18 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Thu May 21, 2009 8:22 pm
I'll help if you want :wink:
for the record, the 33's were happy on the truck before I put the body lift in. Suspension would be a must for 33's though.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Fri May 22, 2009 12:39 am
Started sorting out the rear bumper,
Progress so far
De-rusted rear cross member
Cut some 6mm plate to size and welded to the rear chassis
Painted crossmember and new mounting brackets
Cut some 10mm plate to size for the rear recovery points
Off work tomorrow and am hoping the rain holds off so I can finish it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Fri May 22, 2009 7:50 pm
Wheee... Got my CB antenna mount today :D
Found a nice friendly metalworks shop, and after finally managing to stop gassing to the owner about 4x4's for long enough, had a 13mm hole drilled in the spare wheel mount on my back door.
One quick bend of the hoop thingy later, and the antenna's on. We are wired for sound, hehe :lol:
Piccies to follow, no doubt,
Jim
-----Edit-----
And I bet I have the most novel place for the actual rig itself yet :lol:
Any guesses as to where??
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Fri May 22, 2009 7:56 pm
Removed knackered clutch slave
so now truckless until new part sourced and fitted.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sat May 23, 2009 7:58 am
Fitted in-line primer bulb and non return valve and positioned it above the fuel pump............................................
SHE LIVES :dance: :dance: :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat May 23, 2009 8:38 am
:dance: Good news Ian.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sat May 23, 2009 8:43 am
i plan on a good wash as i still cant drive her till the end o thde month
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sat May 23, 2009 11:05 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat May 23, 2009 11:32 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat May 23, 2009 11:36 am
i done nothing to my baby, but did do a 200 mile round trip, to pick up some new rubber, nice bloke,
viewtopic.php?f=26&t=25421&p=285269#p285269
me little pug never missed a beat
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat May 23, 2009 6:21 pm
Well today I did a cv boot on the citroen (no more moaning about vx..) a cv boot on the LWB and flipped the BJ's on the LWB.
Was really hoping for the shock bushes to be in for the procomps, but Lasuperlate are err late so I'm still on regular shocks.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frontycustoms on Sun May 24, 2009 12:55 am
Got my onboard video recording sorted 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sun May 24, 2009 4:25 pm
Hope it point outside, dont want to see what you pair get upto when your 2 up.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FUDDY MUCKER on Sun May 24, 2009 4:29 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sun May 24, 2009 5:11 pm
painted my rear bumper
