Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Jan 27, 2012 1:06 am
Now the montery there was a motor i wanted ah well i have a trooper now lotus edition collect saturday
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jan 27, 2012 1:10 am
I have to say the build quality is infinitely better, which is nice in some respects, but a pain when you are trying to take stuff apart as everything is double bolted/screwed with extra fastenings blah blah.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jan 27, 2012 1:13 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Jan 27, 2012 1:17 am
Yeah i wont park too close if i make it too a meet bits might falloff mine mysteriosly :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jan 27, 2012 6:46 pm
Well, its been a while but just squeezed 405 miles from one tank of fuel, and the fuel light has not come on yet, well it flickers when I go around a corner a bit quick :wink:
I still have to get the garage for fuel about 7 miles away so I am well chuffed with that.This is taking all the mods into consideration.
I have though fitted smaller tyres for the road AT's and bang 500ml of 2 stroke in a tank :wink:
I have to admit I havent been driving like a saint either :angel:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Jan 27, 2012 8:26 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jan 27, 2012 8:44 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Jan 27, 2012 8:48 pm
No comment to either point ... apart from that my pm inbox is now crammed with questions I have had to answer ;)
I have to admit I am truely over the moon though. I spotted this one a couple of months ago and tried everything I could to get the money together for it. I eventually had to let it go. Chuffed it is going to someone who is going to look after it ... you will look after her won't you Drinks!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Fri Jan 27, 2012 8:54 pm
well first day i have had to play on the truck so half the day trying to sort the resar door out then it rained so rear wheel mount fitted cb arial on just half run but not take long to finish it tomorrow but with luck and good weather i should have my old roof lights on by tomorow night , just ready to get it an oil change :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jan 27, 2012 9:49 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Jan 27, 2012 10:16 pm
Yeah .. I have. If he breaks her I will drive up to Scotland and confiscate it!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Jan 28, 2012 3:24 am
Not today, actually last weekend :oops: , but I've been waiting for my fat fingered friend (Hi Dave :thumbup: ) to email the pic across.
The Monty getting it's feet wet for the first time in my ownership. Did very well actually :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Jan 28, 2012 7:13 am
Lol ... easiest way to wash the underside!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jan 28, 2012 11:15 am
Well thats the Picasso's MOT sorted, it flew through :dance:
So I will just wait for the ice to melt and have a tinker with Triggers Broom 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sat Jan 28, 2012 11:35 am
Todays plan was........................remove old exhaust and replace with one from donor car.
Remove props etc and check breather pipe isnt blocked and get pinion seal out.
Then try and source a new one....proving to be very hard.
Not H.A.P.P.Y. done my back in so another weekend up the spout..... :(
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Well, it's only took me 2 weeks but I washed it :D
Didn't realise how shiny it was.
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jan 28, 2012 5:32 pm
I got carried away in the shed and fitted a new vice to my work top and a cheque plate floor to the front of the shed.
So nothing to the car :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sat Jan 28, 2012 5:41 pm
taken the spare wheel carrier off & strapped the spare in the back & stuck my shackles on the recovery points, also ordered another tow strop from the tinternet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sat Jan 28, 2012 5:47 pm
I have given it a rest as I've used it all week instead of using the vectra.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Sat Jan 28, 2012 6:09 pm
I brought some of the bits for a defender snorkel off evilbay in the week and started to fit it today.
Removed the wing and airbox fitted some flexible pipe and siliconed it in place then when it had gone off a bit gaffered the thing to within an inch of its life and refitted the airbox drilled the wing fed the tubing through and refitted the wing.
Cut the defender back plate to size and shape and re drilled the fixing holes then ran out of useable daylight.
Next comes the tricky bit finding time to fix the upright tube to the A post without cracking the screen then fitting both half's of the snorkel together with flexible pipe.
next I need to feed the tubing from the airbox through and work out a way of fitting the mushroom on the top as there is a difference in diameter of the upright tube and the mushroom.
I want to make a decent job of this bit as it's the bit everyone see's.
Here is a couple of pictures of how far I got today.
http://i1141.photobucket.com/albums/n58 ... oto-23.jpg
http://i1141.photobucket.com/albums/n58 ... oto-24.jpg
wideformat
Vehicle Name: More Trouble
CB Radio.
Users browsing this forum: No registered users and 41 guests
