Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Jan 23, 2012 3:00 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by toj28 on Mon Jan 23, 2012 3:27 pm
i fitted a new airflow meter and cleaned the egr out now to have codes read again and hope its not the dredded number 1 injector lol as my local vx want 480 pound plus v a t exchange lol :shock:
toj28
Vehicle Name: bonnie scotland
Modifications: n/a
i thought it would be a good idea to clean it.
started well, did the inside, thats it :roll:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Jan 23, 2012 9:21 pm
dont worry ill pull you the right way round after you finished looking :D :D
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Jan 23, 2012 9:35 pm
Monterey.
Took it for a brief laning trip yesterday just to see how it went. Pretty good considering it was running on 4 tyres with questionable tread :|
Did the Carwash, Wayfarer and Conquering Hero quite happily. Only slight issue was I managed to tear the n/s/r bumper off it's mounts - but with a bit of bodging it's back on. :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Mon Jan 23, 2012 9:36 pm
Lets get it on!!!!!!!!!!!! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Mon Jan 23, 2012 11:52 pm
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
I was thinking that, but might have to do it closer to the day, the mrs has enough trouble getting in with the help of the steps :lol:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Tue Jan 24, 2012 8:43 am
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Jan 24, 2012 8:15 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Tue Jan 24, 2012 8:25 pm
If you have a blow lamp give it a bit of heat, works every time.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Tue Jan 24, 2012 8:38 pm
Got some new wheels and tyres :D
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Jan 24, 2012 8:47 pm
Monterey
Replaced the alternator belt. What an arse that is. Anyone who says they can do it without removing the aircon pipes from the back of the pump is a liar :|
Flushed I don't know how much brown gunge/rust general crap out of the cooling system and replaced with fresh antifreeze. 2 minute drive is was brown gunge again, I guess I'll be flushing it again at the weekend. :roll:
Dropped the oil and filter.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jan 24, 2012 9:14 pm
Call me a liar Boxy :D
Battery off. Top a/c compressor bolts off. Lever it away from engine and remove ball ache lower rear a/c compressor bolt. Remove lower front a/c compressor bolt. Move a/c compressor away to get to altenator ;)
Now you have opened the a/c system up you will need to get it vacuumed, and charged buddy. Else you will knacker your compressor pump.
I can let yo into a sectet to properly flushing the system. On the passenger side of the engine block, below the very rear face of the fuel pump, next to the engine mount is a small bolt. Its actuall a plug in a plug. This is the drain for the cooling system. Will try to find a picture and post it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Jan 24, 2012 9:29 pm
Seen the pics and read the tutorial mate. Just no way to get any socket or spanner in there from above or below with removing the pipes out of the back of the air con pump. The job was simple when I did that. I didn't put the damn thing back in either. I've considered it an optional extra that I won't need :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jan 24, 2012 9:34 pm
Have to admit I left mine off and replaced with an idler pulley ... you will need a shorter belt though.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Jan 24, 2012 9:53 pm
No, i put the air con pump back, just not the 4th bolt.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jan 24, 2012 10:09 pm
Standard proceedure Boxy ... its what everyone does ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Jan 24, 2012 10:48 pm
Cool. Feel like less of a quitter now :lol:
