Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jan 13, 2012 6:51 pm
Found a little water leak around the water pump. only did it 4 years ago :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Jan 13, 2012 7:01 pm
You put a leak in your water pump four years ago and you only found it now :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jan 13, 2012 7:30 pm
Yer :lol:
Replaced the pump :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Jan 13, 2012 7:56 pm
You can check your timing at the same time Drifty ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jan 13, 2012 8:23 pm
:roll: I suppose so :lol: :lol: :lol: :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Fri Jan 13, 2012 11:10 pm
Used it. Heard a liquid sloshing sound from the rear of the car - turns out its the laminates of the removable roof have collected water. Will drain it tomorrow, weather permitting.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Fri Jan 13, 2012 11:19 pm
drifty water pumps £40 at milners :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Fri Jan 13, 2012 11:56 pm
:clap: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Jan 14, 2012 4:46 pm
today i bolted a step onto mine so i have easy access to the roof :dance:
and when i was driving back from town my car sounded louder than normal and when i looked under it i found my exhaust had split
so went down halforda and got some supplies to patch it up untill me new one arrives for fitting next sat
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jan 14, 2012 5:51 pm
Cheers Rob, got one in the shed :thumbup:
But on further in inspection I think its the thermostat housing that needs either resealing or nipping up :dance:
I had a little electrical contact cleaner spray left so thought sod it, dowsed the alternator in what was left :oops: its charging better than it ever has now :shock: 14.2v and only drops to 13.8 with everything on :D
Then went a walked up a mountain with my daughter and my Mrs :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Jan 14, 2012 5:51 pm
Bought a Landrover Discovery 300TDi :shh: :shh: :silent: :silent:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Sat Jan 14, 2012 5:58 pm
Nice one si 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Jan 14, 2012 6:00 pm
Traitor!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jan 14, 2012 6:03 pm
Leave the guy alone, he likes red metal and spanners .....after all he had a 2.5 and DTI :butt: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Jan 14, 2012 6:04 pm
Red oxide will be my new best friend :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Sat Jan 14, 2012 6:07 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Jan 14, 2012 6:09 pm
Don't pic it up until Monday Ste - assuming it's as described of course. :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Sat Jan 14, 2012 6:14 pm
Ok mate :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Jan 14, 2012 6:25 pm
Last monday till yesterday i was in southampton, the dti dragged my caravan down there no problem, did a few lanes around the salisbury plain and found some mud :D. Also found such a scratchy lane that it ripped my n/s rear light lense off, only noticed it because when i braked the trees and bushes behind me lit up white lol...it was dark.
Tryed to do some lanes in the isle of wight, but most of them had emergency closers on them till mid summer, dispite trail wise saying they were open :(
And now im back, today the front crank seal has started to leak again... the mot is due end of the month as well...so lots of work to do on her :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Jan 14, 2012 7:08 pm
Put my v6 on ebay :cry: :cry: :cry:
