Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jan 03, 2012 12:49 pm
Dunno what time ... just know the mileage was less than the recommended 60,000 miles. Either way the entire lot is getting replaced with nice brand new bits Saturday. Photo's to follow.
Sat in it for an hour watching a film while waiting for some work to do. :D
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Wed Jan 04, 2012 4:15 pm
used mine to take me carp fishing, blanked again :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vauxsqueeks on Wed Jan 04, 2012 7:27 pm
Spent 2 hours under the Fronty on a jack with a grinder cutting away the bolts to remove the center exhaust box..
When trying to refit the new replacement part to the existing pipes..
Damn gaskets dont fit.. now its 10 times noisier :? Will have to finish it tomorrow... roll on take 2!
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Wed Jan 04, 2012 7:36 pm
Why didnt you just drill the holes out mate??
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Wed Jan 04, 2012 10:43 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vauxsqueeks on Wed Jan 04, 2012 11:37 pm
I could have drilled it out, but instead went and bought new gaskets at the local factors. The ones that came with the exhaust would have fitted no doubt it i had bought the whole system from Milner. but as it was just a center box I suppose what I had was just old.
I would have had to cut the ends off the gaskets also and did not think that was a good idea.
Now Gone
vauxsqueeks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Thu Jan 05, 2012 12:22 am
Major power cut so the Fronty is once again being used as a generator via a power pack - well, I've got to be able to see what I'm eating and....the Dakar is on!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jan 06, 2012 5:29 pm
2.5
Removed the gearbox, rad, headlights, rear tailgate and various other bits and pieces.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Fri Jan 06, 2012 6:02 pm
busy day day then Si
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jan 06, 2012 6:03 pm
Yes mate, stopped because it got dark (and bloody cold! )
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gazza1591 on Fri Jan 06, 2012 7:30 pm
gazza1591
Vehicle Name: the tank
Modifications: none as yet but plenty to come
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Fri Jan 06, 2012 7:50 pm
Checked all fluid levels and didnt need to top anything up as normal :D I then packed the truck up ready to go playing in the morning :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Fri Jan 06, 2012 8:39 pm
Shhhaaating this is going to be hoofing mate. What you packed :shock:
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Fri Jan 06, 2012 8:42 pm
Tow ropes :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Fri Jan 06, 2012 9:46 pm
Sweet I've got a few to pull you out matr :lol:
MrTom
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
2" suspension Lift
Roof Rack
Tow Bar
Bucket seats
Rear seats removed
Manual locking Hubs
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Fri Jan 06, 2012 10:12 pm
Shackled up the tow rope and dragged the remaining 18' of tree from side of house. Great tractors these Frontys.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Jan 06, 2012 10:40 pm
least you could after hitting it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vauxsqueeks on Sat Jan 07, 2012 2:50 am
Today I:
Finished the exhaust ( center box fitting ).
Fitted a new cam position sensor.
How come ones from VX for 2.2 Omega's/Astra's etc
are £25
The ones for Frontera's
are £148
:evil: :evil: :evil: :evil:
Really.. Whats the difference - Resistance - several "penny" components ???
Now Gone
vauxsqueeks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sat Jan 07, 2012 7:10 am
That's a bit cr@p isn't it. Do you think its supply and demand costs? Motorcycle tyres are the same. I got speaking to a suit from Dunlop and said the reason bike tyres are so expensive is simply because they don't make as many :(
MrTom
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
2" suspension Lift
Roof Rack
Tow Bar
Bucket seats
Rear seats removed
Manual locking Hubs
Winch bumper
Winch
