Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Dec 17, 2011 4:17 pm
Drove mine to work :) n then FLEW HER HOME!!!!! :dance: :lol: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Dec 17, 2011 4:45 pm
I kinda left mine.at home on the.weekend i am likely to need the old girl most.. opps :oh yer:
I just fitted a DVD head unit to mine and swapped the wheels to my A serie wheelss with BFGoodrich A/T tyres on :D :D
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Bearcat on Sat Dec 17, 2011 6:59 pm
Changed the thermostat, still no heat in the car, did 2.3td heaters ever work?
Bearcat
Registration Year: 1994/M
Vehicle Name: Cat-Cat
Modifications: No Mods
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rseaville on Sat Dec 17, 2011 8:07 pm
Changed all the vac lines for new blue silicone one's, 4x4 fault now gone :D.
Repositioned some of the cables to give them a bit more slack due to body lift.
Jet washed the underside while I had the covers off.
rseaville
Vehicle Name: Tera
Skype Username: rseaville
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Dec 17, 2011 8:35 pm
I drove mine to the hospital whilst i was having an asthma attack i could of called for ambulance but i don't like wasting NHS money :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Dec 17, 2011 8:46 pm
they would of hung up thinking you a crank caller , im guessing your ok.
I did nothing in mine i sat in and played halo 3 on the xbox
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Dec 17, 2011 8:56 pm
Not much, just changed both handbrake cables. Tommorrow the steering gets it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by glynn969 on Sat Dec 17, 2011 10:38 pm
fitted a rear spoiler :mrgreen:
took a bit of modification to the brackets , but it's on ... pics to follow
glynn969
Vehicle Name: Red Monster
headlight protectors
steinmetz grille
pipercross induction kit
safari snorkel
FOG stickers
braided brake hoses
Skype Username: glynn969
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Dec 17, 2011 10:41 pm
Just put some more! fuel in it n now ready to hit the peak tomorow! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sat Dec 17, 2011 10:47 pm
[quote="RatCav"]That was only on the facelift A series and B series Dav. The early A series was done on the light itself.
Always learning, would have thought VX would have incorporated the switch from the start of the range seeing they had it fitted to Astras and probably others years before. :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Dec 17, 2011 10:52 pm
The early A was more isuzu than vauxhall, nothing inside was vauxhallesque at all... :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Dec 17, 2011 10:54 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Dec 17, 2011 10:58 pm
Controvertial, but err err err....yes :wink:
They dont drive as car-like on road as a B, but will put up with a lot more punishment without breakage off road...
The A's only weak spot really is the front diffs, but they more often fail due to driver over exuberance than anything else...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Dec 17, 2011 11:04 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Dec 17, 2011 11:13 pm
Fingers crossed bud :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sat Dec 17, 2011 11:19 pm
:lolno: Got more than my fingers crossed pal!!!!!!!!!!!!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Dec 18, 2011 1:01 am
Today I had an MDF sunroof fitted. Screw you all I've got wood! :shifty:
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wideformat on Sun Dec 18, 2011 9:28 am
I got mine to start at -1 c that will be a first :D
wideformat
Vehicle Name: More Trouble
CB Radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun Dec 18, 2011 12:25 pm
Had to use 4wd to get out of an ice covered car park.
