Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Nov 10, 2011 2:53 pm
means you can fit bigger tyres and your speedo won't be too far out. (hope I've got that the right way around :S )
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Nov 10, 2011 5:49 pm
Yep your right mate... :wink:
Whats changing a diff anyway?....2 days....we sorted my 2.4i at the last weekender in under an hour! :dance: :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Eric on Thu Nov 10, 2011 8:48 pm
Eric
Registration Year: 2002/52
Vehicle Name: Canyonero
Modifications: Nil
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Nov 10, 2011 8:51 pm
Well I am a numpty :wall: :wall:
Richard fitted my new alternator today,the old one only did half a spin and was well shot:lol: ,all went well till :shock: Richard put the volt reader on, it was losing one AMP every second,Richard spent most of the day trying to find the fault,it turned out to be my front fog lights,I did a redneck repair with a bit of tin foil to get them working :roll: so he has discounted them and its stop losing voltage :wall:
So new alternator fitted, and he also fitted me a new Manifold gasket and studs for me, only cost me £110 in total :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Nov 10, 2011 8:55 pm
Bargain! 8) 8) 8) Glad its all up and running again!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Nov 10, 2011 9:09 pm
Thanks Greg :lol:
Lets see how long it last me,before I break something ells :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Thu Nov 10, 2011 9:35 pm
You fixed your lights with tin foil ??? :shock:
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Nov 10, 2011 9:50 pm
Yes Tom
The bloody bulb keeps coming lose so I folded some tin foil up and packed it out,but the tin foil came undone :oh yer: and was coursing the short
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Thu Nov 10, 2011 11:24 pm
Well the speedo aint to far out barley noticable infact, should be better for pulling though :D . Today i fitted new split pins to all ball joints and track rod ends, cleaned the grease of the front brakes, washed it, hoovered it, polished the interior and cleaned the windows.
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Fri Nov 11, 2011 7:16 pm
Removed my well rusted bull bar and had a good look around the front only to discover the whole front end from the inner wheel arches near the front body mounts and the lower body cross member (that holds the radiator) is basically totally rotten :shock: :shock: so now have to figure out if its possible to repair :(
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Nov 11, 2011 7:20 pm
Rob, Colley had that issue with his 2.8 and repaired it, pop a post in the bodywork section and the fixes will flow :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Fri Nov 11, 2011 7:31 pm
I seem to remember a post at some point with the same issue. Trawling through the bodywork section now :) Cheers Drift
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Nov 11, 2011 8:11 pm
Dti
Fitted a new HD battery. Jump starting it off the 2.5 every morning was getting embarrassing.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Sat Nov 12, 2011 8:04 am
gave it a wash...then drove it to work this morning with a smile back on my face, didn't have the radio on for once so i could hear it purring along..so smooth (unlike the old block, that knocked and just ran lumpy)..still need to fix the slight blow from the reducer ring, between the cat and center pipe...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Sat Nov 12, 2011 11:44 am
Yesterday I had a very busy day almost full of bad luck. Went out yesterday morning, upon opening the front door discovered one of the cats had been sick by standing in it so cleared that up. As I made my way to the parents house mum phoned me and wanted a few bits picking up from the wholesalers so I spun round and headed over there. Getting near the wholesalers I stopped at a red light only to be rear ended by an old guy in a new ish Civic who had the cheek to ask me what I was playing at and where I was going. Checking the caravan over as me and the other half are going away for a few days only to discover it had a gas leak some where. And to top it off both the Vauxhall alarm and my upgraded Toad cat 1 both decided to start wailing at 4:30 this morning for no apparent reason.
Regards Ady
adyclemo
Front tow bar.
CB.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Nov 12, 2011 3:24 pm
today i went up town and got the last bits i needed for my onboard computer
so i now have memory map and internet in my car :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sat Nov 12, 2011 4:30 pm
that will help the AA find you if you breakdown :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Nov 12, 2011 4:42 pm
if?????? :shock: :shock: :shock: :shock: :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sat Nov 12, 2011 5:27 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sat Nov 12, 2011 6:15 pm
Well today i decided to remove my front bumper and refit with the brackets that Fatbaz (Stuart) had cut and welded a 50mm extention into the spare front bumper mounts now my bumper should match the body lift.......just need to mod the bullbar tomorrow to allow the bumper to come up behind it.
Before with gap
Old bracket
New bracket
Drum roll
Now nice and snug
Cheers Stuart, you are the Man!!!
Having looked at the pics again the tracking looks way out, drives ok.......... :eh: worried now...
Cheers Pete
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
