Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cav on Sun Nov 06, 2011 1:03 pm
Rolling in my TANK
cav
Vehicle Name: TANK
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Sun Nov 06, 2011 1:22 pm
screaming kids distracted me
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Norse on Sun Nov 06, 2011 1:25 pm
IT support/Advice just ask me
Norse
+2" Sus Lift
+2" Body Lift
DIY Snorkle
Shedload of stickers
To do
Boot Organiser construction
Remove spare wheel holder
Perhaps a CB
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Nov 06, 2011 2:03 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Nov 06, 2011 2:12 pm
I have not read anything to say not too, the only thing I have read is that you are not to use it with WVO or Bio as it goes glooppy :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Nov 06, 2011 2:20 pm
does this mean you diesel guys will get a stroker power band now 8) Drift will be zipping around sounding like a can of bees on steroids :D
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Sun Nov 06, 2011 3:50 pm
hit a concrete bollard. drifts power band would be pretty poor though with all the backpressure reducing mods in his exhaust lol
Gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Nov 06, 2011 3:56 pm
There is only one box on my pipe with no warm up valve or particulate filter, goes like stink :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Sun Nov 06, 2011 5:15 pm
Fitted some door speakers, glad to be rid of them crappy in dash speakers..... :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Nov 06, 2011 5:38 pm
Drove mine to a boot sale and pick up a 8ton 6 meter strop for £5 :thumbup: :thumbup:
Started my project for the winter to get her ready
1st thing was to get rid of the poor burst fuel lines leaking lots of preciouse liquid gold on the tarmac lol.
2nd ordered 7 mtrs of 6mm inner dia and 8mm outer dia semi rigid fuel line nylon so no more rot once done.
3rd Ordered cotton reinforced rubber tubing 8mm inner dia for both ends ( tank and engine end ).
4th Removed tank 4 bolts 2 each side and five jubilee clips , feeder pipe for filler , breather for tank and 3 at pump
filler neck and breather accessed fro wheel arch drivers side , the other three when dropped the tank.
5th Please be carefull when dropping tank try to do when nearly empty fair old weight if full lol use a trolley jack to lower .
6th If youre lucky the four bolts holding the tank straps can be removed but if like mine use the grinder to remove.
7th Jet wash round the edge of the tank to remove all the crud from years past makes it easier to prise out the bashplate.
8th Remove tank from bashplate prise out using pry bar through holes at bottom easiest way.
9th Start sanding grinding away at all rust before painting .
will post more info as i get to doing the rest also post before and after pics asap
martynmcqueenie
Vehicle Name: The Betsy
Modifications: Wind deflectors fitted to all side side windows
Bosch spotlamps
Orange flashing light thingy lol
Refurbed wheels
Chromed towing electrics
12" sub and box with pioneer amp and upgraded component speakers front and back
Will update as i go trying to tidy up 1st
hope this helps and as i say i will post more on fuel lines replacement when i get the time to do this week as i said its the start of a long project stay posted
martynmcqueenie
Bosch spotlamps
Refurbed wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davetheraveuk on Sun Nov 06, 2011 8:20 pm
drove it in to a tree
davetheraveuk
Vehicle Name: fart box
Modifications: muds will have a 2" lift did have a 2.5 muds and a 2" lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Nov 06, 2011 8:26 pm
:rotfl: :rotfl: :rotfl: :rotfl: :rotfl:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alchamist on Sun Nov 06, 2011 8:27 pm
A day late and not my truck, but fitted Biggie G's new radiator ..
The one I took out ...
Doesn't look too bad in that shot ...
This one shows the three pieces it came out in! :lol:
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Nov 06, 2011 8:30 pm
:lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by davetheraveuk on Sun Nov 06, 2011 8:36 pm
I'll just push it out at some point :party:
davetheraveuk
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Nov 06, 2011 8:42 pm
What Dave means is he will hit a tree with the other side and push it out that way! :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sun Nov 06, 2011 9:19 pm
2.5TDS
Drained coolant, full flush and refilled/bled
Swore at it for several hours trying to sort the central locking
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sun Nov 06, 2011 11:01 pm
Washed it !!!!!!!!
Pete
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
