Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Oct 30, 2011 11:49 pm
Stops your steering from being slammed to the side quickly mate helps maintain a straighter line and prevents tramlining (your tyres following grooves in the road surface)
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Oct 30, 2011 11:49 pm
It just suppresses some of the steering input that comes from the wheels sooner than the steering wheel, and stops wheel wobble a bit when you hit small bumps with hooj offset rims. steering just works like normal as the damper is kinda extended/contracted relatively slowly, but the quicker jerks from the wheels are reduced.
Landcruisers and patrols have them as standard.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Oct 30, 2011 11:53 pm
Like your dampers on a boot of a standard hatch back I guess.
I fit a steering damper to every motorcycle I own as you can get what's called a "tank slapper"
Which = brown adrenalin :wtf:
MrTom
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
2" suspension Lift
Roof Rack
Tow Bar
Bucket seats
Rear seats removed
Manual locking Hubs
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sun Oct 30, 2011 11:55 pm
Learn somthing every day :D Are they common on fronties then?
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Oct 30, 2011 11:58 pm
I didn't even know they came as standard on normal road vehicles mate! :shock:
I'm learning too.
MrTom
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
2" suspension Lift
Roof Rack
Tow Bar
Bucket seats
Rear seats removed
Manual locking Hubs
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Oct 31, 2011 12:06 am
Not common on fronties Alfie, I gotta feeling Yaki's has got one but I might be wrong...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Oct 31, 2011 12:22 am
There you go...one of my old FJ60 landcruisers, if you look at the end of the yella arrow you will see the steering damper :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Mon Oct 31, 2011 1:44 pm
Steering dampers were standard fit on range rovers, connected to a lug under the pinion flange and a welded bracket on the track rod. Some defenders had them too only they were connected to the drag link and a bracket bolted to the chassis.
regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Mon Oct 31, 2011 11:11 pm
Being a total sucker for punishment I decided to change my glow plugs this afternoon in the spare hour before hometime.
Finished at 8 oclock. What a pain in the bum,
They were so badly gunged up with carbon I had to leaver them out with a bar, All done now though and she seems to start alot better.
Another job off the list. :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by glynn969 on Mon Oct 31, 2011 11:39 pm
oil and filter changed , tow ball replaced with recovery hitch and electrics repositioned to stop off road damage :mrgreen:
also bled the clutch ( looks like the first time since the truck was new ) what a difference !!! :dance:
glynn969
Vehicle Name: Red Monster
headlight protectors
steinmetz grille
pipercross induction kit
safari snorkel
FOG stickers
braided brake hoses
Skype Username: glynn969
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Tue Nov 01, 2011 11:29 am
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Tue Nov 01, 2011 10:19 pm
Alternater has gave up,and so have I :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Nov 01, 2011 10:22 pm
Bloody hell Jase, thats the only original thing on it :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Tue Nov 01, 2011 10:31 pm
That's a point,it is the original :shock:
It's under charging,then over charging,causing things to blow,like my bloody patience
I give up :cry:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Nov 01, 2011 10:34 pm
Do you reckon thats whats blown all those headgaskets jason? :shock: :shock: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Nov 01, 2011 10:44 pm
For the sake of £30 second hannd one Jason...you know it makes sense, that thing has been dunked a good few times, I am on number 3 :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Tue Nov 01, 2011 10:47 pm
started it for the first time in 5 days...then spent another 118+ a bit for 6months road tax..
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Tue Nov 01, 2011 10:50 pm
It's shorted most of the electrics out on the truck (ECU)
Richards going to have a look at for me.
But I think it will be going on eBay on Tuesday as I have up to Here with it :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Nov 01, 2011 10:54 pm
:shock:
You dare :evil: ................think Snow :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Nov 01, 2011 10:55 pm
