Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sun Oct 23, 2011 6:50 pm
Drove mine to the local airfield (about 15 mins away) to watch my niece do a charity sky dive for the local radio station (Capital FM). Sadly though, due to strong winds her jump was postponed until 5th November, but...with £1,000 raised, she's gonna do it no matter what! :drink:
removed fuel tank started sanding bash plates
inspected fuel lines for replacing
martynmcqueenie
Vehicle Name: The Betsy
Modifications: Wind deflectors fitted to all side side windows
Bosch spotlamps
Orange flashing light thingy lol
Refurbed wheels
Chromed towing electrics
12" sub and box with pioneer amp and upgraded component speakers front and back
Will update as i go trying to tidy up 1st
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Mon Oct 24, 2011 7:26 pm
Changed the heater matrix (2.8 sport), not a bad job to do. Biggest headache is getting the hose clips off to allow removing of the hoses :( , got it all back together including run up and cooling system bled :) , just need to check the steering wheel is straight when the car is driving straight, wasn't before I took it apart. For anyone contemplating doing theirs it took me seven hours, that includes removing and replacing my coms module (I got CB, Satnav, Memory Map, auxillary light switches and anologue clock mounted in a module on the dash above the heater controls, takes about an hour to out and in).
Didn't take the steering column out as suggested in a thread on here, just took the wheel off, I did mess about removing the VX switches and taking the plugs off the back only to find that their wiring is incorporated in the dash loom that unplugs in both footwells leaving the loom attached to the dash, you live and learn :oops: . Took the heater motor unit out as well bdefore putting the dash back in and took out half a bale of hay and leaves (I don't get that lollipop stick in the spokes sound effect anymore) :dance: .
Laters
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Mon Oct 24, 2011 8:37 pm
Turned the interior light on via the light switch, had the car 6 months and only just found it by accident. :oops:
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Oct 24, 2011 8:41 pm
Ive just this minute found out mine is not working :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by glynn969 on Tue Oct 25, 2011 12:11 am
fitted roof bars and an xplorer roof basket ...tomorrow it's the rear , roof mounted flood light :mrgreen: :mrgreen:
glynn969
Vehicle Name: Red Monster
headlight protectors
steinmetz grille
pipercross induction kit
safari snorkel
FOG stickers
braided brake hoses
Skype Username: glynn969
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Tue Oct 25, 2011 6:40 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Bigga on Tue Oct 25, 2011 10:14 am
today i have mostly de-stickered the old girl. :D
Bigga
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Tue Oct 25, 2011 11:22 am
watching the bloody rain washing off all the mud i collected from thetford forest :thumbdown:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Tue Oct 25, 2011 9:13 pm
Its just arrived here and is doing the same thing. Guy at the petrol station said the jet wash was broken. Probably didn't want all the mud on his forecourt. Will get the wife to go in and get a token in her car and then go back with mine. :lol:
mickh
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Oct 25, 2011 9:32 pm
My local Sainsburys petrol station has the cheapest jet wash. When I drive in they give me extra time so I can wash the mud away afterwards.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Tue Oct 25, 2011 10:06 pm
but i wanted to keep my mud :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Tue Oct 25, 2011 10:07 pm
trimmed front bumper and hid the bonnet rust
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Oct 25, 2011 10:43 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Oct 26, 2011 6:05 am
To be honest your only pushing two small wires through. I would find the grommet that the wires for the ECU go through and shove them through there.
As the saying goes "Any hole is a goal"
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Wed Oct 26, 2011 7:52 am
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Oct 26, 2011 8:00 am
Yesterday I took delivery of some Monroe Adventure front shocks for the old girl. 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Oct 26, 2011 9:43 am
Don't blame me if they don't fit Drifty ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Oct 26, 2011 12:01 pm
think it dry enough to do some work on the sport
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Oct 26, 2011 7:20 pm
i dont want to talk about it :x
