Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Oct 07, 2011 10:10 pm
where did you get your new icv jason ? glad shes running ok again :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Oct 07, 2011 10:23 pm
:shock: end of an era Jasons truck sounds like its spot on :shock: :shock: well done fella 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Fri Oct 07, 2011 10:37 pm
Yep Its all fixed :drink: :drink:
Fogman I don't know where he gets his parts from,but I can ask :D
I just like testing them and Breaking them :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by z1baz on Fri Oct 07, 2011 11:32 pm
finally got baby sport`s head gasket done,been a few week but the stupid £400 quote i got in the beginning was totally destroyed by autofix in ebbw vale for............ wait for it...........£200 inc gasket kit, new cambelt kit, oil n filter antifreeze also included was pressure testing and a skim,value for money or what.
the head had been off just before i bought it they knew the gasket had gone so torqued the head bolts right down so far that they had twisted,plus the previous owner had split the head n barrels with a screwdriver n thats the only reason i needed the head skimmed,to get rid of the efn big gouge the idiot had put there.
she`s running sweet now.
k+n 57i kit is on, full cobra safari bull bars on,stainless spare wheel cover is on.waiting on some large driving lamps and a full powerflo exhaust.
anyone got a set of stainless swb side steps they want to part with ??
baz
z1baz
Vehicle Name: baby
Modifications: 16" m+s tyres,k+n 57i,platinum plugs,magnecor 8.5mm leads,fse power boost valve.
new head gasket,cam belt/pulley kit.synthetic oil,water wetter antifreeze/summer coolant.
prolong engine oil enhancer,same for gearbox. full cobra 3"stainless steel bullbar,stainles spare wheel cover,130w 8"driving lamps,rear light conversion,50mm coil assisters/spacers ont back.blue led dash lites,bluetooth cd/radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Oct 07, 2011 11:34 pm
Was some in the for sale section Baz!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Oct 07, 2011 11:38 pm
Drove it for the first time in 2 days. It runs as it should, but it's still no match for the Mrs' 2.5. Drove that tonight and it makes me smile every time!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Oct 08, 2011 6:38 pm
Put 40 litres of professionally refined WVO in the 2.5 today. Have to say the smell is awesome :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun Oct 09, 2011 5:32 pm
(Well, yesterday), son wanted to do some photography for a project he is working on - to the foothills we went and yippee, had to drive up a very poor track with deep muddied puddles, overgrown brush and steep gradient. 4wd lo was the order of the day for a few hundred yards :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Oct 09, 2011 5:44 pm
Went conker picking in it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Oct 09, 2011 8:22 pm
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Oct 09, 2011 8:31 pm
These conkers you loon :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Sun Oct 09, 2011 9:09 pm
finally got the time to take out my old engine (with it's worn crank) tommorow is a day of changing heads and the bit an bobs over, then hopefully getting the useful one back in the engine bay..then Bobby can have his hoist back.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sun Oct 09, 2011 9:11 pm
I looked at mine sitting on the driveway when I pulled up after work. :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Oct 09, 2011 9:26 pm
Got the rear brakes apart and sorted the hand brake - holds on 4 notches now. Started off being a bit of a pain because it's guess work which way the adjustor turns - got peeded off with guessing if I was turning the right way so decided to take the drum off to know for sure. Paid dividends on the off side because the adjustor was over tightened on the closed position and needed attacking with a couple of pairs of grips to loosen off.
Finally found the reason why the full guage wasn't working - broken wires - just need to buy some bullet connectors and reconnect up.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Oct 09, 2011 9:28 pm
well yesterday i was over in birmingham and i left my jacket and my keys in a friends there, only realised half way home :oh yer: :oh yer: :oh yer: (had a few too many :drink: )
so today i broke in through the passenger door and then removed the ignission barrel (im not telling how i did this with out a key) and then went on a look at the local scrappy for a new one. and found non at my local one, so tomorrow i will be gouing to one where there is about 10 fronty a in so i should be able to find one.
so i now need a new barrel and door locks(might as well wile i am there) but my car is now all locked up with the battrey removed for good measure
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sun Oct 09, 2011 10:09 pm
Fitted a new fan belt whilst on the m25 hard shoulder as the old one let go
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Oct 09, 2011 10:13 pm
Fudge
Why didn't you just get the keys posted to you wrapped in the jumper so no knows whats in the package and saves you having to go through all the trouble of getting new barrels. If they send it recorded delivery it would only take a couple of days and they are tracked.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun Oct 09, 2011 10:21 pm
Used the truck today and thankfully the radio is behaving itself.
(Fudge, another practice to get forgotten keys home is to have them posted to a pals address ensuring the pal knows to expect them and the sender puts no information in the package to indicate who the keys are intended for.
Have done it myself :oops: )
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Oct 09, 2011 10:42 pm
well i can have it all working tomorrow, insted of tuesday at the earliest.
so i can get to work on tuesday. and i have been needing to change my barrel since some one tried to nick it and dammaged it with the previous owner.
as well tomorrow i will be doing my cam belt
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by SPEEDBIRD 202 on Mon Oct 10, 2011 8:44 am
SPEEDBIRD 202
