Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Oct 02, 2011 4:03 pm
used thre lwb to shunt the sport out the drive turn it around then shunt it back in. And gave it a jump start and agian it fired into life never fails bit annoyed about battery drain though.
Any intresting bargain at the car booty
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Oct 02, 2011 4:05 pm
No, I was really good and didnt even look around :dance:
Made a ton but it was a bit quiet.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Oct 02, 2011 4:10 pm
Nice find hipo
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Oct 02, 2011 4:14 pm
I went to a car boot aswell and all i found was an Alchemist up to no good!!!!!! :wink: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Oct 02, 2011 4:24 pm
:lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by locospit on Sun Oct 02, 2011 5:23 pm
Swapped the corroded back wheel for a spare we have knocking around in the shed on Julies Sport
Finally wired my spot lamps in.
Mine is a 1998 S 3.2 Limited & My Good lady has a 1998 T 2.2 Sport RS
Same colour, same spec, twins separated at birth ?
Check out our cars here viewtopic.php?f=46&t=44777
Comment on our cars here viewtopic.php?f=115&t=44871
locospit
Modifications: Mine = A Line Soft Nudge bar and Side steps, Pirelli Scorpion rubber, upgraded speakers front & back- soon twin stainless exhaust, K&N 57i. The Fiancee's full top end rebuild,New Front pipe & cat, HG, stainless cat back exhaust with oval trim, A Line Soft Nudge bar with spots & side steps. EGR bonnet guard, Upgraded speakers in front - Both to be treated to a stereo head unit upgrade at some stage
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sun Oct 02, 2011 5:26 pm
replaced my brake pipes just get it retested tomorrow and a pass hopefully.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by locospit on Sun Oct 02, 2011 6:41 pm
Nice looking motor Hipo.
Arden Blue ?
If they did a LWB in that colour I would have one.
locospit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loki on Sun Oct 02, 2011 7:42 pm
Bought it and gave it a decent clean :D
Loki
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Oct 02, 2011 8:08 pm
Hi Loki. When you get a bit of time fill in your profile so if you ever have a question we can see what vehicle you have and where you are, that way you will get a quicker answer. Maybe not the right one but hey never mind eyh!!!!!! :drink: :drink: :mrgreen: :mrgreen:
Regards Bobster.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Oct 02, 2011 9:03 pm
today i did a carboot and sold a few bits and one set of tyres that i got for £2 for £20 :dance:
then tonight me and foggy finished off my front drive. by bolting on the drive sharft and filling the diff with oil. then bolting on the bach plates,
so i now have a working 4wd again :dance: :dance: :dance:
then me and foggy went out for a drive down a 3-4mile lane near us
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sun Oct 02, 2011 9:31 pm
& a good laugh it was :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Oct 02, 2011 10:07 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sun Oct 02, 2011 10:15 pm
we will show it to you andy :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Oct 03, 2011 7:04 pm
Out with Chel shopping today. Called into Maccy D's for lunch, and when I shut the engine off, the dreaded fuel cut off thingy that needs replacing (has since I bought her in January :oops: ) messed up again, and the engine over ran. ECU is now in limp mode once again. Not such a problem at the min though, as I'm not using her much with having a company car. Oh well.....will get it sorted eventually. :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Oct 03, 2011 8:39 pm
you have no luck with that truck these days
I just secured a set of cobra bucket seat for a reasonible price off ebay
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Oct 03, 2011 8:42 pm
Been fine for a while now Stu. Just one of those things that will keep cropping up until such time as I get the new switch fitted. Guess I'll have to find it first. lol.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Oct 03, 2011 8:46 pm
today i receved my cambelt kit, will be doing that this weekend.
and then i took it our to test the front diff and all working :D
will put pic's up later
and my rear wheels are on flat ground :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Oct 04, 2011 8:00 am
Nice one Fudge ... you must of been drunk when you took the photo dude ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vauxsqueeks on Tue Oct 04, 2011 9:24 am
I used a 15+ year old MIG welder to seal up a small hole crack on my exhaust last night, at least that was the plan..
The welder although barely used in all this time seemed ok, with a new bottle of CO2 gas and a new feed tip. However may be I should have also changed the solder wire as this was a little dirty, gritty. After leaving about 1/4 inch of "bird crap" welding I burnt a half inch hole in the exhaust/muffler. :(
So re-adjusted the wire feeder and was all good, smooth delivery. Now I need a grinder to remove all the crap welding so I can re-seal the holes again. :oops:
Need to practice!
Saturday I am planning to do :
Front Brake Pads
Upper and Lower Ball Joints, NSF, OSF
Read Brake Pads
Grinding and re-Welding the exhaust
Hand brake adjustment, - one side is not working as well as the other..
Drain the Coolant, remove the radiator wash out the Welsh mud & re-fit.
It's going to be busy..
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
