Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sun Sep 25, 2011 6:55 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Sep 25, 2011 6:55 pm
Just broke down on the M54 coming back from Wales aux belt snapped plus one of the pullies seased. So now waiting for the RAC.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Sep 25, 2011 8:43 pm
Changed the lower ball joint and outer CV boot on both sides and re-greased every thing in site that needed it.
Think the ball joints needed doing as there was a couple of mm play in each one. No more squeaks now and oddly enough the knocking has stopped too... :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Sep 25, 2011 8:48 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Sep 25, 2011 9:00 pm
today i decided to go to a carboot and i for a working pair of 8" spot lights for £2 :dance:
as well as a halfords pro breaker bar and scockets that was £10er the lot
and then when i got home i decided i would do a diff swap, god it was fun on my own untill fogman turned up at 6, and was a great help
so all i need to do now is put the drive sharft back in and i will have fully working 4wd :dance: :dance:
and then i have to bolt the bash plates on as well
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Sep 25, 2011 9:16 pm
Shear bolts are normal bolts that the hex head shears off when hitting a certain torque. The reason is to prevent people undoing them to nick your ignition barrel. He has replaced them with normal bolts to eliminate hassle in the future.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Sep 25, 2011 9:24 pm
Whos gonna nick the ignition barrel Neal???? :lol:
But removing the barrell means you remove the steering lock and then all you need to do is pop the ignition switch out and start the car with a screwdriver!
Stear bolts prevent it being unbolted as Neal said, nought to do with crashing. more to with not getting your car half-inched! :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Sep 25, 2011 9:34 pm
Ok badly described. Either way the end result is the same. Cheers for clearing it up Greg :-D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Sep 25, 2011 9:43 pm
:lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Mon Sep 26, 2011 12:06 am
just fitted my new reversing camera kit with 7" screen and then dug an s video lead so i can run my laptop through it just need to sort out a usb gps dongle and then i can use it for sat nav, dvds using the av1 option as the camera kicks in when in reverse on av2.
just need to update my gps software on lappy to include something decent like meomery map just got find a decent gps dongle any suggestions a usb one would do
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Sep 26, 2011 12:16 am
I drove mine home at a good 70mph from a fantastic North Wales laning weekend with a bunch of mentalists and some hens (the mentalists and hens where not in my car ) :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Sep 26, 2011 9:16 am
i followed you, but broke the truck as it got close to home, bloody egr blank, will have to get that done,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Mon Sep 26, 2011 9:37 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Sep 26, 2011 10:04 am
:lol: :lol: :lol: sorry :rotfl: :rotfl:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Mon Sep 26, 2011 12:39 pm
Quick check-over, some air in the tyres and arranged for the new tyres to be fitted.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Sep 26, 2011 12:52 pm
Not what ive done but more what im going to do when i get home from work. Go get me stiches out then take the battery off the truck and charge it up as i have'nt been in it for over a week now and there's not enough of the sparky stuff left init to turn it over!!!! :cry:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Mon Sep 26, 2011 1:16 pm
just sat watching the cow pooh water bake on nice and crusty in the sun :shock:
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Sep 26, 2011 9:10 pm
washed it, and fixed the egr blanking plate
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Sep 26, 2011 9:11 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Sep 26, 2011 9:19 pm
Plugged the code reader in as I was getting an EML light on at the end of the days laning yesterday. All the codes told me the injection pump was fubared :roll:
Sprayed some contact cleaner on the multiplugs and now it's perfect again. :roll:
