Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Thu Aug 25, 2011 6:51 pm
oh yes
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john boy on Thu Aug 25, 2011 7:37 pm
Wired up me work light on the rear :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Thu Aug 25, 2011 8:38 pm
Replaced NS wheel bearing (inner & outer)
Replaced OS upper ball joint
Replaced OS lower ball joint
Replace NS rear axel U-bolts (and realigned axel)
Well, not me exactly, but they needed doing.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Aug 25, 2011 8:57 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Thu Aug 25, 2011 9:00 pm
Relocated a new trailer electrics socket after I mangled the old one.......... :? :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Thu Aug 25, 2011 9:02 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Aug 25, 2011 10:23 pm
ive added one or 2 more bits for the weekender.
will put pic's up if they survive the weekend
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Aug 25, 2011 10:31 pm
....or I'll put pics up later if they fall off up the woods, and Sally and I find em when tidying!!! :butt: :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Aug 26, 2011 10:28 am
Dammit ... towing electrics ... will have to relocate them when I get there. I am bound to lose them otherwise.
As for me I sent Mrs RatCav to the diesel engine specialists with the spare set of 2.8 injectors to be cleaned and tested :twisted:
Lets see how they turn out.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Fri Aug 26, 2011 5:11 pm
Fitted push button starting, cleaned egr valve and wired cb in properly
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Fri Aug 26, 2011 5:55 pm
Put the old tank in for an mot and she failed, but.......................... only on a bit of welding I knew would need doing, so a good result.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Aug 26, 2011 6:15 pm
good news mick :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Aug 26, 2011 7:24 pm
well if your all having side exit exhaust i want one
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Aug 26, 2011 11:36 pm
Made up my steel gear box bash plate today ready for the woods! :D. What a pig of a thing to get right tho!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by steveM on Fri Aug 26, 2011 11:45 pm
steveM
Modifications: 2.0 Sport Transglobe.
Inherited K&N filter
R/diff sorted
31x10.5 15's
August jobs:
+4" suspension,
Fuel pipes, s/s straps, recon the guard,
Service
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Aug 27, 2011 12:04 am
Yeah thats probally the one, I dont know if they are the same on a A tho....but its a right arse of a shape on the B...In the end I ditched the idea of copying the original plastic one and made my own shape lol...was much easyer :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Sat Aug 27, 2011 5:19 pm
refitted the head new water pump all new gaskets just got a belt change and oil change to go then shes back
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Sat Aug 27, 2011 9:02 pm
Today I went out and ordered £180 worth of parts :roll:
And as it's been stood for a week,I thought I will give it a run,but it would not start :evil:
Ow well I will just have to wait till the new parts turn up :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Aug 27, 2011 9:41 pm
i swore at it, i hit it, i smashed the ball joints of, fitted new upper and lower ball joints and shock on one side, (not completely back together yet,
still got to put the drive shaft back in, (needed a new boot on the inside) hub has got to back on, caliper, and manual hubs, then i can start on the other side, lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Aug 27, 2011 11:27 pm
I drowned it bashed it and muddied it
