How many miles & what's gone wrong ?
got my shed in 2003 , p reg 1996 2.5 tds 5 door now got 117,000 + on the clock
new bits or replaced /bodged parts
new rear diff cover
starter motor x2 referb [as the first burnt out]
clutch flywheel + clutch + master cylinder + recon gearbox
bulkhead weld 4 mastercylinder
front discs +pads
rear pads+hand brake shoes
hand brake cables x2 [thanks vauxhall 4 ripping me off]
loose steering column
broke weld on door stop [opens rearly wide now]
speedo works when it wants[tell speed by rev counter + gear]
rear n/side window does not open
replacment fuel float
drivers door seal leakes
plastic turbo pipe split over rad
glow plugs
hydrolic lifters need replacing
great fun to drive , would not be without it, but the mitsi sport looks very nice
mutley 20561
Modifications: happy the way it is at the moment,,, but gonna change it
Re: How many miles & what's gone wrong ? by Ulf on Sun Sep 20, 2009 7:55 pm
Yeah, that remindes me,
hand brake cables x2 3000 SEK, that is about £200, that is robbery and fraud... :!: :!:
Getting the part from the Opel dealer is that like that, except for the oil filter, air filter and the shock absorbers. Good pricing there!
/Ulf
Ulf
Re: How many miles & what's gone wrong ? by rmas on Wed Sep 30, 2009 5:23 pm
Fronty 2.3 TD LWB, 1994/04
Replaced thermostat - 245,000 kms
Replaced expansion tank cap - 247.000 kms (earlier was shot)
Refurbished head, New head gasket, water pump, head bolts, rocker arms, valve seals, - 255,000 kms (head gasket shot)
Replaced two front shocks - 256,000 kms (Earlier were leaking oil)
so far thats it in less than one year :(
need replacing:
rubber thingy in the transmission (dont know the exact name)
some oil leaks in the engine (dont know where they are exactly)
rear diff oil
front brakes
2.3 DTR LWB
rmas
Vehicle Name: The Antichrist
Modifications: Snorkel
bilstein shocks
255/75/R15 tyres
pager alarm
5 cm body lift
5 cm suspension lift
rear tinted windows
Alan 121 Midland CB
Roof Rack with Spare tyre
Re: How many miles & what's gone wrong ? by EnglishOak on Thu Nov 19, 2009 2:57 am
2.3td 121k miles 92 plate, just had 2x front bearings new discs and pads, new centre box and rear pipe, also replaced the ariel as it was letting water into the car ( old rubber seals :evil: ) £300
1992 2.3Td Lwb My current Toy who knows what will happen
1995 2.4i lwb Dark Green with silver tinted windows
1994 2.4i lwb blue/green, bosch4 spark pulgs and uprated leads
EnglishOak
Registration Year: 1992/K
Vehicle Name: The Tank
Modifications: 8" spotlamps
