Frontera Technical Support • View topic - Physical help required with suspension replacement
Well done all. Looks like a great result. Sorry I could not make it. Hope you get the rest done soon Rachie :D
Vehicle Name: Dino
Well done all, glad it went well.
MuddyFairy
Vehicle Name: Mini Monty
Modifications: 2.2 1998 S Reg LWB in dark metallic green, needs engine. RIP
2.4i 1994 M Reg LWB Carabic Blue, Replaced suspension all around. Planned suspension lift, CB, winch etc. When time and money allows. SOLD
Planning on getting a shorty when money allows!
2.0 1998 R reg SWB (Finally!)
Skype Username: Rachael_Edwards1
Ooo, just remembered a Techi-Tip
:idea: If you can't remove the split pin from the castle nuts on the top ball joint and want to undo the nut and shear off the split pin, fit a the ring of the spanner to the nut with the other end resting near the shock (which is going to be replaced) - then turn the steering wheel and let the hyraulic force do the work for you.
Lawrence Image
good idea that was. they were going to try and do some more today i believe.
MuddyFairy
we did have fun. and if he does tackle it you have fog at your finger tips :D
Do you think it is safe to drive as it is with just the one side to do? Only I can't get it to a garage without an MOT or tax it without an MOT. So I wouldn't be able to get it fixed unless Gareth manages to fix it. If I could get it to a garage to MOT then if it did pass I may be able to get the garage to complete the work??
Maybe I should just risk it and try it at MOT? Most of the work is done they may just give me an advisory??? What do you think?
MuddyFairy
You can legally drive a car that has no tax or mot to a pre arranged appointment for an mot at a garage or mot testing station and back home again afterwards, regardless of whether or not the car passes.
MuddyFairy
As long as the car is booked in for the MOT, you should be fine ;)
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
O~k so now all hubby needs is another pair of hands to help him get the parts off. He is a bit unsure of how to take the auto hubs to bits...can someone either talk him through it when he does it or post a step by step guide? I think he will need some advice so he doesnt ruin my car. :) ;) I'm not strong enough to hold the spanner or to hit it with a hammer!
MuddyFairy
thats my post hope it helps :D
Hubby already bookmarked that post. Thank you. Do I need a new curclip then? We didnt replace the old one on the other side did we?
i think im gonna get the garage to do it as hubs isnt confident and I need the car all done otherwise I will not have a job to go to at this rate. I need it to get to work and for work purposes. Thanks again. :mrgreen:
MuddyFairy
