Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jul 21, 2011 11:46 pm
pic three is my favorite and set the number plate back to the grill at the back then just put some ducts to pump air round and down as was looking as a subaru bonnet vents two side grills and a great whopping mouth for the top at the back to rush plent of air straight at the top of the lump
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by steveM on Thu Jul 21, 2011 11:54 pm
steveM
Modifications: 2.0 Sport Transglobe.
Inherited K&N filter
R/diff sorted
31x10.5 15's
August jobs:
+4" suspension,
Fuel pipes, s/s straps, recon the guard,
Service
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Thu Jul 21, 2011 11:58 pm
Thanks Steve, would be interesting to know as my diff cover isn't as dry on the outside as it should be. Securing bolts will need wd40 too as the top ones, in particular, are not for letting go.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rod 2.4 on Fri Jul 22, 2011 12:19 am
took mine in for the mot retest and passed. they tested my handbrake again which they didnt need to do as it passed the test last week and i didnt any repairs to the brakes for the retest. funny thing is the hanbrake is only working on the one wheel but it seemed to hold up on the rollers today. :lol:
my 3.1 fly's by the 3.0's like there ther sitting still. coz the most of them are.
rod 2.4
Vehicle Name: tonka
Modifications: 3.1 td isuzu trooper [ the fronty's big brother]
body lifted 1.5 inch's
33 mud tyres
pro comp +2 0n the front and the torsion bar's wound up to match
custom front crossmember and bumper with winch mounts
big sound system
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jul 22, 2011 3:59 pm
took mine for a MOT and passed, well it was going to fail actually , but he took a spanner to the horn and clattered it until it started working and also replaced the fog light bulb (both free fixes) and then he passed it :D Always helps if your MOT tester is a 4x4 nut :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Jul 22, 2011 4:35 pm
congratulations on the passes guys :wink: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Jul 22, 2011 4:43 pm
Well done Si. Great result. :party:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Jul 22, 2011 9:24 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jul 22, 2011 9:26 pm
Treat if first then paint it :wink:
Took the battery out to charge it because the stupid solar panel must be knackered and drained it, thats about it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Jul 22, 2011 9:46 pm
have you checked the wire is still connected to the terminals drift because mine snapped off, the wires really flimsy, i resolded it back on & its working fine again :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jul 22, 2011 9:51 pm
Yer went over it, but even so it should not drain the battery if the terminal was broken, I think the non return diode thingy is faulty, when it get dark I think it has taken more power than its produced due to the fault.
Ive got a thread running here :D
viewtopic.php?f=9&t=44639
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Jul 22, 2011 10:57 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Jul 22, 2011 11:50 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by steveM on Sat Jul 23, 2011 12:12 am
CPU died suddenly today, had to rush to computer store to get it replaced (£25 less for fronty :( ) But without FOG there'd be no fronty for long anyway, so money well spent!
steveM
R/diff sorted
31x10.5 15's
August jobs:
+4" suspension,
Service
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Jul 23, 2011 12:15 am
Like your logic Steve, well done 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Jul 23, 2011 3:50 pm
This morning i fitted my nice new RED RELAY Thanks to Frontera member **Plumjam** who kindley supplied the said item. Now my headlight washers work perfectley!!!! :dance: :dance: :dance:
Thanks again Plumjam (aka Tony) :drink: :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat Jul 23, 2011 3:56 pm
Sat and let my darling little daughter drive from Nottingham to skeggy all in one go which was not bad as this was only the second time she has drive the big v6 and she loved the fact being auto no gears to change and with the cruise control it is even lazier
Only one scary moment when a dozy bint pulled out not realising my daughter was giving it large on the loud pedal.
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by steveM on Sat Jul 23, 2011 4:43 pm
Tried checking 31" tyre for fit.. got as far as lifting the F/O/S (29") tyre enough to move - slightly - then 'fssh fssh', no more lift, oil seal gone.
Moral of the story: Read the advice on avoiding 2 tonne trolley jacks for the Fronty 'before' buying, not 'after' :roll:
steveM
R/diff sorted
31x10.5 15's
August jobs:
+4" suspension,
Service
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Jul 23, 2011 5:08 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat Jul 23, 2011 5:37 pm
Just fitted the new bracket for holding the nudge bat I got with thanks to Glynn. Modded the front bolts so they were longer and put to m8 nuts in the normal screws and mounted the number plate to the holes I had put in before so the plate rest against the 2 m8 bolts and so supports the number plate and it sits higher so does not obstruct the air flow as much as it would normally
It also leaves me room for my new spots to go underneath when i get them
Big thanks to Glynn for the bracket :dance:
AskDean
