Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jul 20, 2011 3:42 pm
touch hairy wood i have never had an engine issue with the sport.
On look out for a lock up to store sport for a month or so bro in law might know someone
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Wed Jul 20, 2011 4:15 pm
fitted the soft a bar i go off andy at the weekend with a 95p store bodge
started with some shelf brackets curtesy of the 95p store in the shed cut to make the center mount brackets
then attach to bumper and a bar and bolt on
then bolt on number plate tohid bodget brackets
then use spare thorttle cable and cruze control cable mount off the carbs to hold broken bottom bracket till filler can be applied
job done for today time to get some filler
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jul 21, 2011 5:45 pm
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Jul 21, 2011 5:47 pm
You got a bargain there 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Jul 21, 2011 5:48 pm
WOW WHAT A RESULT!! Nice one Dean. :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jul 21, 2011 6:09 pm
i know kust considering what formation to mout them in either 5 up front as alight bar infront of the sunroof or go 3 in the middle of the nudge bar where there is holes for two and then mount the other two wither on the top of the nudge so i can see them from in side so i know the nudge has not fell off see above images for why. or below under numberplate so .
considered putting 2 each side on the out side and ine in the top will photo shop some options over the next few days to see what the wife approve of and what i can do with the bits i have. now i have managed to find a proper centre bracket thanks to glynn
was considering either these
http://www.ebay.co.uk/itm/VOLVO-SCANIA-DAF-CAMION-LKW-STEEL-TRUCK-GRILL-LIGHT-BAR-/140573695676?pt=UK_CarsParts_Vehicles_CommercialVehicleParts_SM&hash=item20bad85ebc
or these for the roof
http://www.ebay.co.uk/itm/IVECO-EURO-CARGO-92-02-TRUCK-ROOF-LIGHT-BAR-HIBAR-/390094784615?pt=UK_CarsParts_Vehicles_CommercialVehicleParts_SM&hash=item5ad3760867
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Thu Jul 21, 2011 6:51 pm
If using them for "on road" use, I believe they should be fitted in pairs; eg. 2,4,6 etc.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jul 21, 2011 10:11 pm
i dont mean to be funny but lights on a light bar they tend to be in 5s
and there is no statue i know off that stiplates the amount of or sequence that fog or high beam lights have to be in, from my understanding of the law the lights on the front of the vehicle have to be white, and as long as your normal driving lights are white and on the front there ok,
spots and fogs are classed as additinal lighting and so not part of the mot and as long as they are not above i think it is 500w as this is where they dazzle on coming traffic if used as driving lights then they are legal as full beam should not be used when on coming traffic is present.
someone on here will no dout have the exact definition
seeing as most lorry bars are either 3 low and 5 high see the links for the lights i was thinking of buying.
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Jul 21, 2011 10:15 pm
Roof lights are illegal to use on the road in the UK even if they are fog lights, I think the fog lights need to be mounted below the line of the headlights, but roof lights are definitely illegal on UK roads.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Jul 21, 2011 10:16 pm
As far as I'm aware Dean, any roof lights are illegal when used on the road...regardless of how many there are. Only the ones on the nudge bar would be allowed for on road use. BUT I COULD BE WRONG! :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jul 21, 2011 10:17 pm
so if roof lights are illegal in the uk how come so many lorries have them and so may 4x4 have them and i could of swore i said i was putting them in the soft nudge bar i got off andy as a moot point on the subject
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Jul 21, 2011 10:24 pm
It isn't illegal to have them fitted, but it IS ILLEGAL to use them!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Jul 21, 2011 10:27 pm
You said light bar so assumed you where fitting them to the roof not the bull bar :wink:
As said they can not be used but can be fitted, they may get used offroad but no on lanes as thats a public highway or used as work lights.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Thu Jul 21, 2011 10:49 pm
Going off topic slightly with this aspect but have a look at the Road Vehicle Lighting Regulations 1989 - full legislative should be contained in it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jul 21, 2011 11:27 pm
this is what i was on about when all this started
one of these 4 options quick photoshop mock up to give demo only not these lamps before any one starts my ones are white not blue
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Jul 21, 2011 11:34 pm
If I had to choose it would be pic number three, I think there may be too many though, be careful you dont obstruct air flow to the rad :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Jul 21, 2011 11:38 pm
I agree with Drifty. Pic three is the bast. I however would put them all on a roof bar, and get two round ones for the nudge bar. But that's just me. :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Thu Jul 21, 2011 11:38 pm
If I had to choose,I would have to agree with Ste and pic number 3. 8)
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by steveM on Thu Jul 21, 2011 11:40 pm
yesterday..
left the Fronty at local 1-man garage (pressure test radiator & few other checks), asked him to reseal r/diff same time.
'before' (after many hits with wd40):
'after'
steveM
Modifications: 2.0 Sport Transglobe.
Inherited K&N filter
R/diff sorted
31x10.5 15's
August jobs:
+4" suspension,
Fuel pipes, s/s straps, recon the guard,
Service
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Thu Jul 21, 2011 11:43 pm
Thats a really tidy job SteveM, has he recoated inside the cover for you? If so, what did he use?
