Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Jul 10, 2011 5:56 pm
cool bobby.
fixed my rear diff seal, (top bolts where finger tight, bottom bolts had no seal behind them, and there seam to be two different colored sealants on there, red and white,) just waiting for it to dry, then drop some new fluid in there,
fixed my front oil leak, oil filter was lose, so tightened it up, jobs a good-en,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sun Jul 10, 2011 6:17 pm
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sun Jul 10, 2011 8:02 pm
LOL @ Jeoh
With many thanks to Alfie for the assistance, the Sport now has 4 new +2" Rough Country shocks, a refurbished spider in the rear prop (used a good one from a spare front prop - yes, they're the same size) and the rock slider sills are now welded to the body sills, filled and given a coat of paint. We found some other jobs to do, but they will have to wait for another session.
In return, assisted Alfie in dropping the tank off the 2.8 and replaced the two snapped tank straps.
A good day.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jul 10, 2011 8:09 pm
:oh yer: :well done: :well done: :well done: :well done:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Jul 10, 2011 9:44 pm
Well done Lawrence, did you get those rear arches welded up mate? Glad you had somthing to do Alfie you seemed a bit left out at the BBQ. :(
Regards to you both Bobster.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Sun Jul 10, 2011 9:55 pm
Washed and vacuumed the truck :shock:
Now i can see all the dents and scratches, i will have to get it dirty again :lol:
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sun Jul 10, 2011 10:03 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jul 11, 2011 8:58 am
Not today but yesterday (Sunday) ... myself and Robertmillsav spent the day with Hipo cahnging his rear crank seal (again). First impressions are looking good. Ran it for 15-20 mins with the gearbox off then whipped the flywheel off to double check and no leakage. Then in the evening after we had put it all back together (again with no extra or missing bolts :? ) went for a 30 min test drive to double check. Nothing bleeding out the bottom. 10 hours from beginning to end including stopping for lunch and several tea and ciggy breaks.
Told him to drive it like a Granny on Sunday going to church for the next 200 miles to bed it in and both myself and Rob demanded that he change the oil from the tar he has in there to nice new fresh stuff.
I ache today.
Mental note: Do not get into postion under a truck with a flywheel on your chest prventing you from moving when Dan has had curry the night before and wind that will peel paint!!! :evil: :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Jul 11, 2011 9:08 am
Yesterday...
My NSR window was lowered by the wife. Not a good idea as the damn thing doesn't go up without assistance, so...I had to remove the interior trim, and help the window up whilst Chel pressed the "up" button. :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Jul 11, 2011 6:42 pm
Thank you for your help Ratcav and Rob! :D
viewtopic.php?f=45&t=44503
PS. I wasnt the only person that was making yours eyes water....own up then Rob :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Jul 12, 2011 5:18 pm
Someone posted a great vid of a guy claying a car to remove imperfections and contamination/fallout from car body paintwork a while ago. The reason I was so interested is that after washing my Fronty the bodywork felt like it had ingrained grit all over it (fallout) and whilst it looked OK, it bugged me , so whilst I was in the local factors spending £100 on various other kit I bought a 'T-Cut classic clay bar kit' for £18 - 15% discount.
As well as that I was hoping that it might help with some fairly major scratches I had running down the O/S front wing which looked a bit unsightly.
for those of you that don't know, 'claying' surprise surprise involves you rubbing in even straight strokes a flattened ball of clay with some liberal amounts of liquid sprayed over the treated area to stop the clay sticking and potentially damaging the paintwork. After very little effort the clay began to glide over the surface where at first it had struggled a little. Below is a pic of the clay after rubbing a small area of the bonnet. Bear in mind I did not start claying the car until I had thoroughly washed the car with hot water and Triple Wax car shampoo first, yet still the clay looked like this after very little effort.
This pic shows the surface properly wetted and clayed awaiting a final buff
Getting less impurities on the clay now - time to buff
Now I can't believe I was daft enough not to take a 'before' piccy of this wing and bonnet area, but you have to take it from me it was dull and scratched and looked terrible.
Anyway, here's the after pic.
The body now feels like glass with an amazing silky sheen on it. The idea is that future polishing/washind should give better results now that I have done the initial hard work with the clay.
EDIT: Oh, and don't make the simple mistake that I did after spraying my alloys with acid using a very similiar spray bottle to the one that came with the clay polish ....:oops: I'm sure you can guess what happened... :axe:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Tue Jul 12, 2011 6:00 pm
Looked at it parked on the drive and wished I had the money to keep it :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Jul 12, 2011 7:05 pm
Gutted Colley. Is trading down to a cheaper one not an option ?
Decided to drop the oil and filter - It's been nearly a year since I last did it :oops: :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Tue Jul 12, 2011 7:16 pm
Took it for it's mot since it has been of the road for about a year (cat c) It passed :shock: :dance: :dance:
Only an advissory on front brake imballance, want to replace the discs and pads soon anyway.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Tue Jul 12, 2011 7:41 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Jul 13, 2011 4:50 am
Changed oil and filter, even after 20k miles the oil didnt feel all that bad :D Maybe because since its last change its had 4litres of topup...only holds 5.5 litres :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Jul 13, 2011 5:04 am
You were up early to do that then!!!! Ide read all the post by half 3 and you posted at 03:50!!!!! :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Jul 13, 2011 5:26 am
I havnt been to bed yet :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Jul 13, 2011 5:40 am
Dirty Stop Up !!!!!!! :mrgreen: :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Wed Jul 13, 2011 6:57 am
