Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Jul 05, 2011 7:57 pm
Hmm 2.6, Im thinking the engine parts are hard to get hold of, are they not 32 spline hubs too?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by problem child on Tue Jul 05, 2011 8:02 pm
Fitted new batteries to the remote, realigned it and hey presto remote locking returns! :D Also painted the fuel tank carrier black. 8)
Experience is what you got by not having it when you need it.
problem child
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Jul 05, 2011 10:32 pm
Had a bit of a wheel/tyre swap around.
Removed the 2 x 255/75/15 Goodyear Wrangler ATR's I got from johnnybbad last weekend from the pepperpot rims and had them put on the rims I got earlier this year, took the two duelers (265/70/15) off the front off the truck and moved the two Wranglers from the rear to the front and then put the two new (to me) wranglers on the rear.
Ended up with 4 v/good 255/75/15 Goodyear Wrangler ATR's on 'A' Series Sport Alloy Rims on the car plus a spare (repaired the puncture) sat on the back. The two good duelers that came off the front are sat in the shed, so once I've replaced the 2 old worn out duelers that came off the car a couple of months ago and are still sat on the rims I will end up with a set of ATR's and a set of Road Tyres :D
Oh and theres 4 empty pepper pots (15") to clean up and paint as well. Wonder if I can get them on the wifes MX5?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jul 06, 2011 12:37 am
aye here is hoping engine runs.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jul 06, 2011 8:13 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Jul 06, 2011 10:07 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jul 06, 2011 12:23 pm
The only thing geographical mechanically about Isuzu is the badges they put on them depending on where and who they exported them to ... i.e. Isuzu Trooper (uk), Isuzu Bighorn (Japan), Vauxhall Monterey (uk) ... all the same.
Only exception to this is LHD/RHD and some 2.8's for were chain cam but they are rare.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Jul 06, 2011 12:27 pm
I adjusted the steering on Beasty. Hopefully that'll cure some of the wandering. Shan't be holding my breath though! :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Jul 06, 2011 1:38 pm
as my radiator exploded at the FOG Annual Meet i had to get one from tom so i could get home.
so today i made two into one
as the one from tom had most of the fins missing and mine had a hole in the top i decided to make one good radiator out of the two.
so i removed the top of both radiator's cleaned the seal on the good one then put some instant gasket on it. placed it on the good bottom half then bent all the clips to make a good seal. job done :dance: :dance:
my old one
one from tom
top removed
new good radiator
then i painted my off road wheels black
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Jul 06, 2011 1:40 pm
Cracked on last night with Sals 2.8 shorty...
Got the knackered clutch off and removed the flywheel, replaced the crank oil seal (cheers Dwifty)...which was a fight and a half! It had a 2 piece on it in, the other came out easy but the inner took ages of much swearing to get out.
Refitted the flywheel and new clutch (cheers Frenchfarmer) and refitted the gearbox and bolted up...
Decided to call it a day as engine needs a service and getting to oil filter is much easier with everything removed, and exhaust is gonna get some mods ie removing the 3ton silencer box also as well as the quick warm up pointless thing...but wanted to run it past Sal that she was happy with it growling a little bit more!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Jul 06, 2011 1:41 pm
Well done Andy...neat job mate... 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rod 2.4 on Wed Jul 06, 2011 8:11 pm
as mines for the mot in the morning i thought i had better cover the rusty hole in the rear bumper that i blasted thru with the power washer the other week :oops: . so fixed it umm i mean bodged it up using a cutting from a tin lid :lol: and a couple of nut n bolts. it only has to last the half hour of the mot test then i will sort a new bumper somtime. but at least thers no sharp edges sticking out now lol. aslo give it a good wash and fixed the blow out from the cat. was just loose. here a few pics of the bodge job bumper feel free to fall about laughing :lol: :lol: .
and its all clean again.
my 3.1 fly's by the 3.0's like there ther sitting still. coz the most of them are.
rod 2.4
Vehicle Name: tonka
Modifications: 3.1 td isuzu trooper [ the fronty's big brother]
body lifted 1.5 inch's
33 mud tyres
pro comp +2 0n the front and the torsion bar's wound up to match
custom front crossmember and bumper with winch mounts
big sound system
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Jul 06, 2011 8:13 pm
You could fit a nice bright reversing light in that hole 8) top bodge though :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Wed Jul 06, 2011 9:38 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jul 06, 2011 10:44 pm
must be a few compatible parts in this country saw a 88 for sale on ebay for 800 there hoping plenty in scrappy . i will have to scavenge each part i find needs done i guess ach well every one loves a scrappy day
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Jul 07, 2011 8:44 am
Its what I do Drinks. My garage is slowly filling up. I am going to have to have a massive clear out of all my old Cavalier parts and random rubbish I have accumulated over the years which I will never need anymore. In fact I might as well start this weekend. Hate to think whats at the back of my garage.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Thu Jul 07, 2011 11:08 am
if that old spare wheel is going to be orphaned after your garage clearout Ratty ill adopt it from you ,im going to remove my pepperpot spare & replace it with my spare steel, its a bit rusty so i need a cover to tidy it up a bit :wink:
yesterday i transplanted my cb from my newer old truck into my older new truck
today i sewed the rip in the gearstick gaitor, that will have to do untill i track dowm a better one & installed an air freshner :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Thu Jul 07, 2011 11:27 am
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Thu Jul 07, 2011 12:27 pm
Well took the 2.8 in for her mot at 11am and she failed :( :(
o/s head light no dip or main beam
o/s/f brake pipes only the 3 you can see lol
1 advisory both rear shocks just starting to leak
Not bad i don't think
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Jul 07, 2011 12:47 pm
Fogman
If you mean the old cover I had on .. that unfortunatly had to sacrifice itself to make room for the one I have at the moment ... basically it fell apart :(
