Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Jun 24, 2011 10:12 pm
were did u get ur chrome lpg badge lovely
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri Jun 24, 2011 10:23 pm
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Jun 24, 2011 10:44 pm
:dance: :dance:
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Jun 25, 2011 2:26 pm
Today my spring loaded cb aerial flattener thingy arrived today....I fitted it and wish the rest of the truck worked as well as this did! :(
cb aerial UP:
cb aerial DOWN:
When flattened its still lower than the roof lights, so nothing to worry about, and I can flatten it from the drivers seat, so no need to stop and pull over if I see a low bridge or tree :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sat Jun 25, 2011 3:30 pm
Put more rubbish inside.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john boy on Sat Jun 25, 2011 3:52 pm
Been at work since 7.30 this morning :shock: new pads all round, new shocks all round, rear brake pipe modified for more travel on the rear, bleed the brakes now after the seals inverted there selves in the master cylnder took 3 hours to sort out the problem :roll: :shock: :shock: and finally new diff back plate on and axel oil changed :D :D :D :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sat Jun 25, 2011 4:08 pm
I didn't actually do anything. Robbie did though. He stripped down my front hubs and brakes and replaced the discs and pads with nice shiny new ones. He then greased the bearings and hubs up and replaced everything.
Cheers Rob. :drink:
Now the pedal doesn't got to the floor every time I try to stop her. Feels nice and reassuring. :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sat Jun 25, 2011 4:17 pm
changed the fuel filter need the codes read though.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sat Jun 25, 2011 7:25 pm
And fitted my cb
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sat Jun 25, 2011 7:29 pm
That's where I'm (eventually) gonna put mine. Did you have to cut much out of the back?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sat Jun 25, 2011 10:58 pm
all i did was cut the back off midland 38 fits with loads of room. it's getting the cb to stay in is the awkward part
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Jun 26, 2011 1:51 am
number plate double sided sticky stuff,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lewishilliard on Sun Jun 26, 2011 4:44 pm
Fitted a central lap belt so can fit the 3 kids :D , and changed oil/air/fuel filter, unfortunatly failed with the fuel filter and she wont start but think I know how to fix it and will try again tomorrow :roll:
I like Cake
lewishilliard
Registration Year: 1999/S
Vehicle Name: Gremlin
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sun Jun 26, 2011 4:48 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Jun 26, 2011 4:53 pm
your right james, it would need to go to vosa testing station, then dvla would have to be informed, then the insurance would need to know,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lewishilliard on Sun Jun 26, 2011 5:03 pm
I did tell the insurance and they said it was fine ?? will ring Vosa tomorrow and take it to be tested, not taking kids in it at mo anyway, just put it in for emergencies
I like Cake
lewishilliard
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Jun 26, 2011 5:11 pm
good man, better to be safe than sorry,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun Jun 26, 2011 9:55 pm
Thought I had best clear out bits and pieces before the Fronty goes for MOT tomorrow, then found the battery was half dead :x
I bet its been that radio "live" feed playing up again - as soon as I put the radio fully home in its holder the display starts acting up. I had removed the radio facia last week thinking that would be OK but it appears the radio set itself has been drinking the battery.
So, jump-starter getting chraged up for the morning - solar panel doing its bit of whats left of the evening daylight - thankfully daylight should start shortly after 3.30am so the solar panel will have another 5 hours work under its belt by the time I need to fire the Fronty up.
Just hope the battery isn't goosed.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sun Jun 26, 2011 10:36 pm
Noticed that she was looking a bit dull so washed, coluor magic applied, polished and sealed. She looks alot better.
Checked all the fluids etc ready for a run to Weston tomorrow and fitted a new url sticker to the back window :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sun Jun 26, 2011 10:38 pm
put together a quick bodge for my cb aerial and fitted spots.
