Re: WHAT YOU DID TO YOUR TRUCK TODAY! by red5 on Wed Jun 22, 2011 4:51 pm
MOT - passed (ish) :-)
Oil, Air and fuel filters. Took handbrake cables and shoes off (after MOT) - mostly fell apart.
Started compiling list of stuff to do. It's long.
Sam. Somewhat poorer, but happier avec MOT.
red5
Some dentage.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Wed Jun 22, 2011 7:32 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Jun 22, 2011 9:40 pm
today i picked up some tyres i got
mum helping to move them
and the tyre on a rim :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jun 22, 2011 10:05 pm
What size are they????
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Jun 22, 2011 10:07 pm
offically 285/75 r16's
but about 33"
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Jun 22, 2011 10:08 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rod 2.4 on Wed Jun 22, 2011 10:35 pm
in tha last few days ive give it a good t-cut sanded and painted a few more bits n bobs fitted a new set of flexi arches ect. and used it to tow for the first . took my caravan for a service. was amazed at how hard it pulls almost forgot i had the van on the back a few times :o :o
my 3.1 fly's by the 3.0's like there ther sitting still. coz the most of them are.
rod 2.4
Vehicle Name: tonka
Modifications: 3.1 td isuzu trooper [ the fronty's big brother]
body lifted 1.5 inch's
33 mud tyres
pro comp +2 0n the front and the torsion bar's wound up to match
custom front crossmember and bumper with winch mounts
big sound system
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jun 22, 2011 11:07 pm
Nice one Fudge ... as for me it was day 3 of the WD40 treatment ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Jun 22, 2011 11:14 pm
have you got the shackles made up then?
as i didnt get the metal off you at he weekend
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Jun 22, 2011 11:40 pm
Got fed up 'tacking' while trying to go in a straight line while on the way home from work, so after tea I jacked the thing up and onto axle stands to get the weight off the front wheels then undid the lock nut on the steering box adjuster and tightend things up a bit. Quick full lock test to make sure it wasent tooo tight and then a test drive having tightened it all back up. Much better, it goes in a straight line now without having to muck about.
Total time taken? No more than an hour start to finish :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jun 22, 2011 11:48 pm
Maybe Fudge ... just need a welder and a lick of paint :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Jun 22, 2011 11:57 pm
FFS.
Removed both rear calipers, one of the slide bolts on the o/s had to be hammered out :roll: That won't have been sliding much then :evil:
Other side wasn't as bad, but discs and pads both mullered. Top it all I think I buggered me hernia at the same time :evil: :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Jun 23, 2011 1:33 am
Nothing to mine, but welded up the rear diff in Retropedros 2.8 shorty... 8) 8) 8)
Pete tried, quite succesfully to demolish the workshop, reversing his car into the door and ripping the doorframe/wall out....soon fixed with big hammers though!
Then took it for a test round the woods...and it worked really well...infact too well...
We had a bit of a moment, (understatement of the century!) and kinda layed it on its side, luckily I was out of the car and managed to hold it from going right over...(you know when a car is well over when you are standing on the Offside, and are holding it up by the roof rail on the NEARSIDE which is right in front of you!!! it still had an easy 6ft under the nsr tyre and about 5ft under the nsf!)...
after a bit of very careful shunting, we got it stable and Pete just managed to squeeze out of the drivers window and helped me to push it back to more sensible angle. we then shunted it again until it came down a bit more and was on the 2 wheels o/s and the rock slider on the offside, then I could finally let go and attach the winch cable to a tree and drag the front down levelling the car so it could be driven out.
Was all a bit worrying :shock:
In hindsight it wasnt the best idea to reverse into the tyre changing hole to get it all kinda controlled and acrobatic with its new locked up rear end...all was well and it was looking good at an impressive angle until the osr spun about 2 revolutions as the nsr climbed the bank on the other side...
The combination of a very aggressive tyre, with most of the weight of the car on it in the bottom of the tyre changing hole which was waterlogged infill earth, meant that the tyre in just a couple of revolutions dug an 18" deep hole, which then put the car well past its centre of gravity, and it was going over... :shock: :shock: :shock:
No exageration when I say I was holding the left had roof rail kinda just above my chest height when standing on the right of the car...and it was everything I could do to hold it from going completely onto its side. It was that far over that I couldnt push it back to its CofG point, in fact the pair of us couldnt, we just got it more level so it was wedged on its rock sliders and n/s tyres.
Carnage...OSR quarter a bit more dented, OSF wing a bit more dented where they were on the ground, 1/4 of tank of diesel leaked out of the filler where we think the cap popped off when the rear quarter flexed...and 2 people with more grey hairs than they started out with! :shock:
Will have to get Pete to do it again on Saturday, so we can get some pics this time!!! 8)
See I told ya you could get into all sorts of new trouble with it locked up Pete! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Jun 23, 2011 8:56 am
Erm Greg.....
:ttiwwp:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Jun 23, 2011 9:00 am
No possibility of pics mate...if I had let go to take one, the car would have gone right over! :shock: :shock: :shock:
If there ever was an excuse for no pics, this was deffo it... :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Jun 23, 2011 9:02 am
That's no excuse mate. I've heard all about your off roading antics. You should have been prepared for carnage. :lol lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Jun 23, 2011 9:13 am
Carnage maybe....Capsize NO! Plus it was about 11pm, pitch dark in the woods with only the one car!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Thu Jun 23, 2011 6:54 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Jun 23, 2011 7:32 pm
Fudge How much did they set you back.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Thu Jun 23, 2011 8:00 pm
im not reveling hat yet
but lets say the only way hey could have been cheeper is if i nicked them (or nearenougth)
and today i cut a hole in my diff again to weld it up, and i am thinking of making a nice ish sized access flap (no joke)
and when i got home from work i finished putting one of my new tyres onto a 16" steel wheel and got more size comparisons
and next to the car
Users browsing this forum: Majestic-12 [Bot] and 27 guests
