Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue May 24, 2011 8:47 am
Droppin the sport of for mot
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue May 24, 2011 10:14 am
Cheers Foggy ... seems its that time of year for a lot of us. Good luck with yours as well. Expecting to fail and handbrake efficiency ... Mk.I's always do :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue May 24, 2011 10:45 am
Spongy brakes will be one of mine didnt have a second man to work the pedal
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue May 24, 2011 12:16 pm
Mk.I Trooper handbrakes are made up of 5 lengths of cable running from the dash mounted handbrake. They stretch after a while. Also the adjusters on the rear calipers are pants and have to be continuously tweaked as the pads wear. Pain in the proverbial. Will nip them up for the test to hopefully get a pass, then slacken them slightly to prevent bind.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Tue May 24, 2011 6:49 pm
This afternoon power was lost in some parts of Argyll, including where I am - consequently the Fronty is now being used as a generator via a power converter to allow the family to maintain a bit of "normality". At least I know the cooling fan is working OK - hopefully no damage being done.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue May 24, 2011 10:03 pm
Well i picked it an hour ago then went shopping why the delay.
Failed but a good fail
Offside windscreen wiper not clearing screen
Nearside headlamp aim to low
Nearside position lamp excessive deteriorated so that light is not visible from a reasonible distance
offside frontwheel bearing rough when rotated
Not a bad fail the wheel bearing cost me £45 quid for the N/S last year an i had to order it. i suspected the wheel bearing may flag up
i think the rear side light is the bulb
Advisories
offside and nearside anti roll bar linkage has slight play
and slight free play in steering.
_________________
Made in scotland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue May 24, 2011 10:05 pm
bad news dav
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Tue May 24, 2011 11:40 pm
Power was off for about 3 hours during which time the Fronty was used as a generator - enough to power the TV, Decocoder, lighting and a charger.
Cooling fan cut in and out as necessary, engine never boiled, oil pressure stayed about a quarter/half despite being well warm. No steam so very impressed.
An unusual use admittedly.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed May 25, 2011 12:20 am
you will have the greenies round checking yer carbon foot print they can check it up thier :butt:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Wed May 25, 2011 11:28 am
Self preservation Stu. I am not quite as dismissive of green matters as JC of Top Gear :D
Will maybe have a go at washing the sea salt spray off the car :?
Well today I condemned the Elephant to the carpark in the sky .
gearbox input shaft bearing buggered
So I decided to investigate further as to what caused it and my lack of drive ,the box turns by hand so not seized ,so I put a bolt in the bell housing and used a screwdriver to turn the engine via the suprisingly intact flywheel and had to dive out of the way as it jumped off the engine and tried to wreak it`s horrible vengence on my nut . All six of the bolts holding it on had sheared.
The money pit is being broken for bits pm me if you wants any.
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Wed May 25, 2011 7:45 pm
turned right at the lights and died and now refuses to start kin pile of junk
put link here to video of engine trying to fire as advice needed
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=22&t=43565
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed May 25, 2011 10:48 pm
sorted the rear light turned out the morrision emergency kit i had lying around is not worth a duck so bought a new bulb lovely bright now.
Didthe bearings on the front wheel im still getting up and down movment im thinking ball joint as balljoint was anadvisory in the mot i have the retest the morra dunno should strip it an try tighten it more i tightend it right up until wheel stopped moving freely then loosend a bit so im confused
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed May 25, 2011 10:50 pm
I put Chugga up for sale. See the link in my signature. :cry:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed May 25, 2011 10:55 pm
why
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed May 25, 2011 11:02 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu May 26, 2011 12:01 pm
PASSED
Mot`d just need to sort insurance. dig out sleeping bag and gear hitch trailer tent . Then get ready for off roading at the
SCOTTISH MUD CLUB MAY MAYHEM
Ofroading , camping , barbcue ing, bantering , drinking, stucking , laughing , photo ing and bonfire oh yeah im so looking forward to this . Its gonna be really wet n muddy and the river is gonna be deep and i may have 4wd this time
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri May 27, 2011 5:47 pm
took my drivers side head off and through it in the back of a van to see if it can be refurbished as the exhaust cam journals are shafted if not then have to buy a new head and not ammused at the 160 to 228 prices for the only two i can find :butt: :butt: :butt: :butt:
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri May 27, 2011 5:58 pm
using it to go down to santa pod
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Fri May 27, 2011 6:17 pm
jammi git
AskDean
