Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri May 20, 2011 7:49 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri May 20, 2011 8:21 pm
I only know coz the on on my LWB rattled about when I got it. A mate of mine told me to adjust the rubbers. :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri May 20, 2011 8:59 pm
Undersealed the chassi so it should be rust free it was waxoiled last week my hands are black.
Tank guard and heat shield fitted this time
healdlights indicators and grill fittes
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by akers159 on Fri May 20, 2011 11:26 pm
Worried, like an expectant father, truck in for MOT :?
Best Nobby
1999 (T) Limited 2.2 DTI Heavy Oil LWB
`Chlanna nan con thigibh a so's gheib sibh feail'
akers159
Vehicle Name: Dusso Weyn
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri May 20, 2011 11:32 pm
Washed the last of the annual clay/mud off it. What the hell was in that stuff? It's a nightmare :evil:
. Also expecting MPG to improve after remove what felt like 1/2 a tonne of the stuff off crossmembers, sumpgaurds (the ones that are still attached) and chassis.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Sat May 21, 2011 11:29 am
re-checked my timing and found it to be a couple of teeth out..that'll explain the lumpy running at low revs..all sweet now..think that the tensioner bolt had worked itself loose, letting it the belt slip a little. did feel what you could describe as a "kick" from the engine a couple of days ago.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fishingmad on Sat May 21, 2011 12:20 pm
Well over the last couple of weeks,I've fitted rear springs,exhaust,front bumper corner,tarted up the brown rusty bits!,welded rear wheel arch,new pads,stripped and serviced front calipers,and today...................................................... MOT..............PASS :dance: :dance:
fishingmad
Model: 2.5 TDS Transglobe 5dr
Vehicle Name: bag of bolts
Modifications: trooper rear springs,sport star alloys,cb,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Sat May 21, 2011 2:16 pm
Eventualy tightened the fan belt today (The squeeling finaly got on my nerves :lol: )
Gave the heater matrix a flush out (lots of brown gunk came out but still no real heating)
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat May 21, 2011 3:28 pm
Got the exhaust gasket now its pee down with rain
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat May 21, 2011 5:00 pm
went out after doing the head gasket last week and it sounds like i have bent a valve as it is knocking like a bitch
AskDean
Skype Username: askdean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 21, 2011 5:05 pm
Double check your timing buddy ... that could be the issue.
Oh and I replaced my windscreen washer pump as my plans for this afternoon were scuppered ... got a brand new one for my 21 year old Trooper off ebay for £7 delivered.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat May 21, 2011 5:20 pm
well if tomorrows plans are going the same way, i know a car that needs some work ratcav
and today i fitted my bucket seat,
so bucket seat and subframe for £10.99 :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat May 21, 2011 5:28 pm
i think more than the timing but will see tomorrow when i take it to bits
see this thread for the video of it running
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=45&t=43471
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 21, 2011 5:55 pm
Turn the crank over by hand and listen for any clouts. Probably easier to hear it with the plugs out.
Sorry Fudge .. building a pagoda tomorrow.
Though I had Dan last night asking if I can help him change his rear crank seal .. apparently its leaking faster then the Exxon Valdez at the moment. I weighed the options up and oil leak ranked higher on list of things to change than tired clutch. We are doing it on the weekend before the woods weekender down at his in Cambridge.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by AskDean on Sat May 21, 2011 6:20 pm
going to try that out as i think it night have jumped a tooth or two as well since it was pt back together as well
thanks
AskDean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 21, 2011 6:57 pm
Entirely possible to jump a tooth if not tensioned properly.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat May 21, 2011 8:21 pm
I cleaned my EGR, was prity bad, but I expected it to be worse tbh.
Picys: :D
And jobs a good'un
Oh and a short vid of the EGR doing its thing, also it makes the 2.2dti sound like a tractor when the EGR is out.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by red5 on Sat May 21, 2011 10:19 pm
About 230 miles back from gateshead after collection without anything breaking.
Slowly, but got there. nice.
red5
Some dentage.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 21, 2011 10:37 pm
Just need to do the inlet manifold and the butterflys now Dan ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat May 21, 2011 10:44 pm
yeah i know! :O it looks nasty in there lol, but that means removing the injector pipes and bleeding the system again and, well I'm to lazy lol. cleaning the EGR has almost compleatly removed the woble at 2k rpm, so Im happy :)
