Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Tue Apr 26, 2011 7:34 pm
Drove the thing...for the first time in three weeks..oh it feels nice, if slightly odd (after driving the wife's civic)..
new bigend bearings fitted yesterday, oil changed today..(need to add some moly..) sounds so much better and feels great..
So out of pure excitement started loading for the annual..got two more days of work to make sure she's fine though
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Tue Apr 26, 2011 7:47 pm
@ Jontera: Bravo and well done :clap:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Tue Apr 26, 2011 7:59 pm
I washed it,polished it,and painted in the wheel arches,and the chassis
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Apr 26, 2011 9:11 pm
Nice one John :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Tue Apr 26, 2011 10:15 pm
Dismantled dashboard to replace knackered bulb on speedo side of binnacle - got covered in thedried out foam stuff thats been in since new. Filed out a small piece of plastic in the switch blank area of the dashboard to accomodate a VX switch for my roof spots. Established the switch I have acquired is "press in" to turn the component off and with the switch in its outer (normally off) position the component becomes live :? So now writing a wiring diagram to have the switch look "normal" whilst controlled by a concealed master switch. Drilled out a heated seat switch blank to accomodate the "roof lights on" tell-tale LED. All good fun.
Mrs has this evening announced kids want to go exploring at the weekend (possibly from Friday) so I've got the next two days to put it all back together again, and do the oil change and pressure wash underneath and apply the waxoyl :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Apr 26, 2011 10:32 pm
think its gonna rain the next two days, think need to meet up an do some xploring in a wee convoy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Tue Apr 26, 2011 11:31 pm
new bumper, and some strange lights, hehe
:ttiwwp:
Cmon andy lets see :lol:
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Apr 27, 2011 12:11 pm
nar, first viewing will be at the annual meet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul4be on Wed Apr 27, 2011 12:32 pm
New timing belt kit fitted this morning, so good for another 40k or so.
paul4be
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Apr 27, 2011 12:43 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Apr 27, 2011 8:45 pm
Finally adjusted the passenger rear calper so the handbrake could work, only for Fudge to notice both the tail pipe and back box are knackered. When adjusting the handbrake we realised the drivers side caliper is knackered as well :evil: :evil: :evil: :evil: :evil: :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Wed Apr 27, 2011 11:37 pm
replaced the N/S spring as it was snapped and also fitted the 2" lift spacers and wound up the front to match ready for the annual meet :) :)
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Wed Apr 27, 2011 11:44 pm
Nothing on at work this week so truck is sitting on four ramps and I'm halfway through dropping the gearbox to fit new clutch, newclutch master cylinder,new crank case oil seal. gbox and engine oil change and a new oil pressure sender to fit. So I should be all ready for saturday. :D :D
Managed to gat all the cross member bolts out without shearing any off. Will also give the crossmembers and all the protective tin work a coat of paint whilst they're off . Going to be a busy boy tomorrow :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Apr 28, 2011 12:04 am
Bloody ell Alfie :shock: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Thu Apr 28, 2011 12:07 am
Now that is cutting if fine aflie lol
robbie
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Apr 28, 2011 6:48 pm
Well the truck is now ready to get on the road for the Annual Meet. All clean, oil's changed and loaded. Caravan all done and loaded, more like a mobile garage than a caravan. I think my workshop's empty!!!! :wink:
Roll on tomorow morning!!!!!!!!!!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by reecy on Thu Apr 28, 2011 7:33 pm
timing belt, fan belt, power steering belt and water pump all been fitted today.
Thanx, Andy
reecy
Vehicle Name: lean green pullin machine
Modifications: 255/65/16 road tyres on the car
and a set 235/70/15 mud terrains in the shed
removed the side steps
reverse sensors (removed)
30mm wheel spacers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by glynn969 on Thu Apr 28, 2011 7:51 pm
washed it , adjusted the handbrake , and put the old wheels back on incase i get brave over the weekend :D
glynn969
Vehicle Name: Red Monster
headlight protectors
steinmetz grille
pipercross induction kit
safari snorkel
FOG stickers
braided brake hoses
Skype Username: glynn969
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Thu Apr 28, 2011 7:59 pm
new dvd fitted
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
