Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Mon Apr 25, 2011 8:55 pm
got it back from mate he used it to tow a caravan
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Mon Apr 25, 2011 9:21 pm
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Apr 25, 2011 9:28 pm
I squeezed a nut into that gap and bolted my old bars on, but I dont have them anymore as didnt like them :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Apr 25, 2011 9:30 pm
if you can see it i can weld it
all you need is a little tack on it, so 1-2mm welding rod in there on a nice stick set, and there you go
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by akers159 on Mon Apr 25, 2011 9:52 pm
Drilled out and re-tapped two snapped off bleed nipples (rear brakes) completed the front discs, pads bearings and seals change, ready to be bled tomorrow :dance:
Best Nobby
1999 (T) Limited 2.2 DTI Heavy Oil LWB
`Chlanna nan con thigibh a so's gheib sibh feail'
akers159
Vehicle Name: Dusso Weyn
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Mon Apr 25, 2011 9:59 pm
Done the front seat mod that someone posted on here some time ago. Removed seat and wound a 1" ratchet strap across the bottom of the seat packed it with a couple of pieces of cardboard and it took all the sag out giving a much firmer and higher seating position.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Mon Apr 25, 2011 10:47 pm
Prepped my sills for welding tomorrow (hopefully). :lol:
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mid77 on Tue Apr 26, 2011 1:06 am
Gave it a good service, and beat the rear diff cover plate back into shape with a big hammer after noticing the rather large pool of diff oil on the garage floor :oops:
Really need to get me one of those diff protectors
mid77
Modifications: Stock
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Apr 26, 2011 1:24 am
The truck? not a lot. But this wee beasty here
Got peeved off with digging the veg patch over and managed to get this off free cycle. Didnt work when I picked it up (previous owner muttered something about it needing a whole new set of points and ignition coil etc). Got it home, expanded a can of degreaser on it and gave it a proper going over with the jet wash.
Stripped the hand starter off, adjusted the points, cleaned the plug, topped the oil up and then got the 1/2" chucked makito drill out with a cut down 1/2" socket extension well clamped in the chuck. Put the right sized socket on that fitted the starter clutch and turned it over with that for about 10 mins to just clear the cobwebs out. It then fired.
Put it all back together and gave it a go with the cord starter, fires first pull now :D Had a quick go with it, works well. Just gonna get some new drive belts in the morning from halfords because the current ones are well past it and replace the two control cables and levers with some nice shiney new push bike ones as they could be better. Might even give it a coat of paint.
Result me thinks :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Apr 26, 2011 12:45 pm
Im gonna hire one to do back garden
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roo on Tue Apr 26, 2011 1:37 pm
Started to load Gracie May for the coming weekend :dance: :dance:
Roo :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Tue Apr 26, 2011 3:36 pm
I know exactly how that feels Robert. Hope you get at least semi-sorted soon. :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Apr 26, 2011 4:24 pm
Did oil change and added Moly slip with the aid of horses45 and did a bit of fettling on both truck's ready for the big weekend!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Tue Apr 26, 2011 4:41 pm
Oh no,drinks is going to hire a rotavator,better tell his neighbours just incase he gets carried away with it. :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl:
Robertmillsav,I hope that you get your back sorted out soon bud.
______________________________________________________________________________________________________
This is what I got done on The STIG! today.................................but I ran out of Mig welding wire before I could finish the underneath of the plate. :twisted:
The welding may look untidy but once its ground down flush and painted,it will not be seen but if you wack it with a hammer,the plate wont come OFF though. :lol:
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Tue Apr 26, 2011 5:21 pm
good job mate well done for doing it your self
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Finaly got the tyres fitted to the front :D
I now have a full set of 5 spokes on it :D
jpbiketransport
Vehicle Name: yeep
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Apr 26, 2011 5:56 pm
Need piccies of said wheels and tyres!!!!!
I would do but this computer is cr@p and wont let me, :lol:
Its just standard leafer 5 spokes and some michelin alpin tyres that have been sat in the garage for 6 months or more waiting to go on :oops:
jpbiketransport
Vehicle Name: yeep
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Tue Apr 26, 2011 6:13 pm
Fitted a bash plate fixed oil leak
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Apr 26, 2011 6:35 pm
Put front on axles stands the backs are on ramps very dodgy but it not moving. Waitin on friend to weld sill and tank guard then i can get on with waxoilin it.
Last edited by drinksoptional on Tue Apr 26, 2011 8:44 pm, edited 1 time in total.
