Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Thu Apr 21, 2011 11:59 pm
thought i was getting it colley
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Apr 22, 2011 12:00 am
is it working better Jim mate had to replace my refile pipe
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Fri Apr 22, 2011 8:27 am
Used the Sport to go to work yesterday - well, it was forecast to be a nice day and an excuse to roll the top down.
Took the opportunity to repair the broken roof catch - the hinge pin dissapeared last weekend - fortunately I found the little blighter when I returned home and umpacked - another job done.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Fri Apr 22, 2011 8:49 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Apr 22, 2011 3:58 pm
no worries bud, the search continues,
i finally fixed my rear brake from binding,
and kept drift company while he done his rear brakes,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Fri Apr 22, 2011 4:00 pm
Got the headlight working again - hurrah
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Apr 22, 2011 4:02 pm
I put £57 of Tesco's finest unleaded in Chugga. Only the 2nd re-fuel this year...having said tha, she was stood there for three months. :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Apr 22, 2011 4:04 pm
Fitted trooper springs to my B. I assumed the springs were +2'' over the stock Fronty ones but they aren't they are identical in length, so I'm assuming they just don't compress as much. Anyway, it's resulted in a 1 and a quarter inch lift :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Apr 22, 2011 4:06 pm
:well done: Si, :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Fri Apr 22, 2011 4:30 pm
hopefully fixed dodgy power window module
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Apr 22, 2011 6:07 pm
we mounted Arial for scanner and sorted my hand held cb
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Apr 22, 2011 6:22 pm
Started taking it apart!!!!!!Clock is ticking to the annual...this is gonna be a mad one with more midnight oil than can be believed!!! :shock: :shock: :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Apr 22, 2011 6:24 pm
good luck mate hope all goes well
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Apr 22, 2011 6:27 pm
Took my hub covers and wheel nuts off for Badboy, changed rear discs and pads, tightened and greased up front wheel bearings and overhauled the locking hubs, changed the thermostat back to the 2.8 one for the summer, the 3.1 can go back in wintertime, and that is about it 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Apr 22, 2011 6:29 pm
Cheers Dazz....and sounds like you've been busy Ste! :shock: :shock: :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by reecy on Fri Apr 22, 2011 6:57 pm
got my mud tyres blown up and fitted and should have a full cb set if the guy emails back :D
then were already for the 9th of june 8) :D :D
Thanx, Andy
reecy
Vehicle Name: lean green pullin machine
Modifications: 255/65/16 road tyres on the car
and a set 235/70/15 mud terrains in the shed
removed the side steps
reverse sensors (removed)
30mm wheel spacers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Apr 22, 2011 8:08 pm
I investigated my exhaust problem and found out that the rubber cushion/mount thing has let go of its bolts at one end, so will be gettin a new one next week because I don't trust super glue to be able to take the weight of the truck sitting on the centre box :P
then I fixed (i hope) the small oil leak I made when I fixed the 4x4 system. :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Apr 22, 2011 8:12 pm
You need to use superglue wrapped it Duck tape Hipo...would be structural then! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Apr 22, 2011 8:15 pm
Livewire Frontera
