Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Wed Apr 20, 2011 6:52 pm
has he checked the egr valve yet ? :D :D :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Apr 20, 2011 6:54 pm
Does he even know what/where it is? :lol lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Apr 20, 2011 6:55 pm
hahahahha,
when i fit the new gasket tomorrow i'm gonna blank it off too so i will never have trouble with it again :dance:
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Apr 20, 2011 7:04 pm
I started mine, it went, then turned it off after a bit.
New rear pads and discs at some point this weekend.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by millenaire on Wed Apr 20, 2011 7:40 pm
All I did was wash and hoover the beast, and applied some Monster energy decals.
I spent a lot of money on booze, birds and fast cars. The rest I just squandered.
millenaire
Vehicle Name: Black Beast of Arrrgggh
Modifications: Fitted Bose sound system from my now scrapped Alfa Romeo, fitted some tasty spot and fog lights. Fixed speedo problem, cleaned egr and sorted vac pipe issues.
Hammerite and Waxoyl underneath, it's got new discs, pads and copper brake pipes all round. watch this space for the next exciting installment lol.
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Apr 20, 2011 7:44 pm
I took Chugga on a nice drive up to Newcastle today. Was certainly different to Beasty, and coz there's no rear window, makes for a very different experience.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Wed Apr 20, 2011 8:41 pm
Today i thought i should start on the long list of jobs on the V6 :D
Anyhow after breaking a couple of bolts and realizing that i needed a pump to drain the axles i got pissssssssed off and packed all my tool away and left it :evil: :evil:
The way things are going i might have to give the annual meet a miss :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Apr 20, 2011 9:26 pm
Got in it, started it, drove 29.3 miles, stopped and turned it off. Got out.
Got in it, started it, drove 3.4 miles and followed an 'Albert' for half a mile. Stopped, turned it off and got out.
Got in it, started it, drove 3.4 miles. Stopped, turned it off and got out.
About it for today I think, boringly I didnt even manage to scare any 'little' cars while driving down the wiltshire lanes :(
Tried and failed to blank the EGR off with scouse tin so just gonna get new gasket tomorrow and have done :(
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Apr 20, 2011 9:29 pm
An "Albert"??? :confused:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul4be on Wed Apr 20, 2011 9:38 pm
The advisory that I got from the MOT yesterday for slight play in the wheel bearing was actually the top ball joint :shock: :shock:
Changed it today. It was an absolute sod to get out. Seperated so that the central spindle just spun when I tried to undo the nut. Managed to get hold of it with a pair of stilsons, so done now. The ball joint had only been on for about 18 months after I changed all 4, with no heavy use and no damage to the rubber etc, typical!!!
paul4be
:rotfl: :rotfl:
no mate empty carlsberg lager can
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by akers159 on Wed Apr 20, 2011 10:01 pm
Attacked the rear OS brakes all going well till I got to the lower M12 bolt on the bracket, it was rounded of :evil: Why OH Why do people put knackered bolts back in :evil:
Ended up cutting it out, now need new bolt and bracket :cry:
Nobby
Best Nobby
1999 (T) Limited 2.2 DTI Heavy Oil LWB
`Chlanna nan con thigibh a so's gheib sibh feail'
akers159
Vehicle Name: Dusso Weyn
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Apr 20, 2011 10:09 pm
'Albert' = C130
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Wed Apr 20, 2011 10:14 pm
i always thought they were called a Fat Albert :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Apr 20, 2011 10:17 pm
Either way, John...I'm still none the wiser. :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul4be on Wed Apr 20, 2011 10:19 pm
paul4be
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Wed Apr 20, 2011 10:20 pm
a c130 is the hercules cargo plane
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by akers159 on Wed Apr 20, 2011 10:34 pm
Smart I like paul4be, but the bolt head is 17mm would this kit fit
Nobby
Best Nobby
akers159
Users browsing this forum: Google [Bot] and 22 guests
