Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Tue Apr 19, 2011 4:17 pm
pics glynn :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Tue Apr 19, 2011 5:41 pm
I had Chugga in for her re-test. SHE PASSED.
:dance: :drink: :party: :to much: :dirty:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Apr 19, 2011 6:06 pm
How much did you need to leave in the ashtray mate??? :lol: :lol: :lol:
Well done fella... 8) 8) 8)
Replaced the spark plugs hoping to clear up the erratic idle and guess what?............. It didn't!! :evil: :cry:
i'm starting to worry that its worse than i feared, i've bought a replacement intake manifold gasket hoping that the existing one has broken down and is sucking a small amount of extra air in, when i put my foot down i get a wiff of fuel so thats my way of thinking failing that could be either head gasket or valves need re-seating if its the head gasket it could be the same problem my old cavalier had in that the head gasket blew between the cylinder bores so dropping the compression but not mixing the oil and water :sick:
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Tue Apr 19, 2011 7:08 pm
put muds on my spare wheels ready for the annual
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Tue Apr 19, 2011 8:26 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by akers159 on Tue Apr 19, 2011 10:30 pm
Got the rear N/S disc and pads changed :dance:
Still waiting for bits for the front two, will start the rear O/S tomorrow :D
Nobby
Best Nobby
1999 (T) Limited 2.2 DTI Heavy Oil LWB
`Chlanna nan con thigibh a so's gheib sibh feail'
akers159
Vehicle Name: Dusso Weyn
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Tue Apr 19, 2011 10:34 pm
well done james
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Apr 19, 2011 11:32 pm
I wired up the CB aerial, took it out into a open area and tested the SWR.....hmmm...it shot well above 3, I let go of the button as soon as it went that high. :'( So tomorrow I'll have to have a scout on here to find out what ive done wrong :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Apr 19, 2011 11:46 pm
Hipo me ole mate, post in ICE section and the guys will help you no end :wink: :D
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Tue Apr 19, 2011 11:59 pm
lee, just check the fookin egr will yer,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Apr 20, 2011 12:14 am
Not wanting to sound all Adminy, but could you keep the techi stuff in the techi threads please guys as this info could be useful for others and it will get lost in here as this is just a thread about a quick overview of what you have done to your car today, not a Q&A forum :wink:
Sorry to get heavy, but in the long run it benefits all members past, present and future 8)
Thanks guys :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Apr 20, 2011 9:46 am
Not today but last night ... replaced the rear nearside brake caliper. Should of been easy, but turned into a nightmare. Stupid stupid Isuzu ... why would you make two brake calipers exactly the same where the only difference is 20mm on the slider. Then spread rumours that the 1990 LWB Lotus Edition has 75mm sliders and then fit 55mm sliders to actual thing. After finding out the new one was 20mm too long I had to cut the old caliper apart to get the seized slider out and compare the two. To make things even more annoying, to get the 55mm slider all they did was literally chop 20mm off the end of the longer one :evil: :evil: :evil:
Then I had to bleed the effin things, then I wasted an hour of my life adjusting the stupidly overly complicated handbrake system only to slacken everything off and give up. Leaving it in gear now when parked. Must sort it though ... MOT end of May :evil: :evil: :evil: :evil: :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Apr 20, 2011 10:03 am
if you need a hand, i can allways pop over ratcav
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Apr 20, 2011 10:21 am
Might tap you for a hand next Wednesday Fudge. It will be done. I will also double triple chack the other side is working properly then as well.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mikovitch on Wed Apr 20, 2011 1:23 pm
Today I have changed the thermostat housing gasket. Hopefully it will stop losing water now.
It seems a little smokey but I am hoping that it is a bit of gasket seal burning off or something. Meh, time will tell I guess!
No More Nails, Duct Tape and a big hammer. Who needs a tool kit?!
mikovitch
Modifications: I have currently modded it so much that is looks suspiciously like a Hilux 3.0l diesel with a 2 inch lift and BFG's hehehe ;) Oh ok, I lied. It IS a hilux. I will be getting another shorty soon tho.
Well had a proper day today sun shining get the beers out and cracked on with the jobs
1st order of business spark plugs
old ones
New ones
What a difference must have done at least 3 or more years with these in
then came the brake pads i checked them yesterday when i had my new tyre (supplied by Gazeddy) :-D fitted at my mate nicks tyre bay he didn't even charge me cos i did the swap using their gear so they didn't have to do the work
they have done some serious mileage judging by whats left compared to the new ones
and then replaced the intake manifold gasket which didn't look too bad but no change in the irratic idle so guess what i did next?? :roll: :oh yer: i removed the EGR valve :dance: gasket was shot made a few phone calls and found that they are a dealer only part my mate Sven on parts couldn't believe the price, he said its the most expensive gasket for its size he's ever known........ £10 inc VAT :shock:
Here's the old gasket, new one arrives from Ellesmere Port tomorrow morning
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by PixelMonkey on Wed Apr 20, 2011 6:41 pm
Fitted a black screen top as i dont have any sunvisor after relining the interior roof awhile back.
Preped my replacement sills ready for welding.
:drink: :drink: in the sunshine :D
PixelMonkey
Vehicle Name: Mini Monsta!
Modifications: Debadged
Mud Guards Removed
Spare Wheel Carrier Removed
Rear Seat Removed
Rear Bumpers Removed
Tinted Windows
Blacked Out Sunroof
Bucket Seats
Black Suede Headlining
Custom Dials
Dash Dress up kit
K&N Induction kit
HID Lights
PipeWerx Exhaust
Roof Spots
Under Bumper Spots
Twin Tone Horns
Ecotek CB-26P
Red L.E.D. Dash Conversion
Blue L.E.D. Interior Lights
+2" Coils
+2" ES9000 Pro Comp Shocks
2" Body Lift
Much much more to come.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Apr 20, 2011 6:43 pm
is that the EGR valve, lee.lol
