Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Apr 10, 2011 9:34 pm
Did this to a Musso :shock:
Someone had been there before :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Sun Apr 10, 2011 9:57 pm
Put the new battery in, epoxied the stoopid indicator cover back on (hopefully it'll hold this time) and got one of my recovery points fitted to the back. Drilling the holes took so damn long I had lost the will to live by the time I'd done one (sat there with the drill for the best part of an hour) so I'll do the other one next week...
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Apr 10, 2011 11:19 pm
lol at you chris,
sorted my rumbling in the front wheel, bearing was a tad lose,
cleaned it again, and found some tins of larger, so i drank a few,
then i came in and just finishing them of
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Apr 11, 2011 12:17 am
Made a Landrover 90 roof rack fit a fronty....and welded a load of accessory brackets to it :lol:
actually does anyone know the recommended weight limit for lwb roof bars????
Will save loads of time if it attaches to the existing bars sooner than directly to the roof... :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Apr 11, 2011 12:38 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Apr 11, 2011 1:06 am
I was thinkin remove the fuel pumo an try see if i can push it out
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Mon Apr 11, 2011 2:34 am
Stu, what about using a pulling plunger - could save disturbing the pump?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Mon Apr 11, 2011 7:01 am
Washed ,polished,hoovered,glass polished inside and out, new seat covers fitted, wheels blacked and now its going to rain :(
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Mon Apr 11, 2011 8:07 am
Spent £115.00 :shock: on parts ready for the spanner meet on saturday new cam belt kit complete with brand new idlers and tensioner, water pump and a new front crankshaft oil seal cam belt kit comes with a 12 month warranty :dance: if the any of the kit fails they willl either pay for the repair of the engine or the supply of a new/recon engine :dance:
So total spent so far including purchase of the truck
£875.00 :shock:
and no mods yet
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mikovitch on Mon Apr 11, 2011 11:56 am
Just pulled the back seat out.
Emptied a tin of wd-40 on the sidestep bolts and that stupid nut and screw that tightens the steering up.
Now I just have to sit and wait..........*yawns*
No More Nails, Duct Tape and a big hammer. Who needs a tool kit?!
mikovitch
Modifications: I have currently modded it so much that is looks suspiciously like a Hilux 3.0l diesel with a 2 inch lift and BFG's hehehe ;) Oh ok, I lied. It IS a hilux. I will be getting another shorty soon tho.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Mon Apr 11, 2011 12:16 pm
Just been on a womble to Machine Mart, and an exploratory underneath the Bus...
Machine Mart bit was easy, £12 for a grease gun, and £7 for an oil suction pump doobrie (for use on the gearbox & diffs). Even filled the grease gun in 5 minutes with just the use of one rag :D
Underneath the Bus though, not so good. It has been mentioned that my funny noise from the rear was a UJ in need of grease (and now there's no sound insulation in the back, that is indeed where the noise is coming from) hence the grease gun. Managed to find and fill the 3 on the front prop, and the 1 at the gearbox end of the rear. However, there is no grease nipple on the diff end UJ. New UJ is in order then :twisted:
Also it's definite that the gearbox rear prop seal leaks (but that's only a tenner from Vx) as does the rear diff pinion seal (Hound Dog found this for me at about £20) but neither of these are show-stoppers. UJ's a little more tricksy, as Milner it seems are out, and I am not paying Vx prices. Time to try the local factors then.
Oh, and the reason for no sound insulation in the back is that it's all down the tip. There was an incident with a large container of waste oil in the back (with the lid not properly on it turned out :oops: ) and some muffin on a pushbike who came round a bend with parked cars on, the wrong side of the road, no lights, and the wrong way up a 1-way bit. Needless to say, I braked, and things, uhh, moved in the back. And said muffin had the cheek to flick *me* the finger before carrying on. :axe:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Mon Apr 11, 2011 3:14 pm
I picked up a prop uj from my local motor factors, cost £20 ish and only took 30 mins to fit.
Checked all the fluids ready for the annual meet :dance:
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Apr 11, 2011 11:18 pm
I wouldnt have....... Braked that is. B***dy things are like an infestation round here, bit like horse's with their 'attitude equipped' riders. Proper pain and IMHO shouldnt be on the road (until they get sufficient training, learn manners and cough up for the road tax, insurance etc).
At least you can stick a nag on the BBQ so they do have some use, but bikes? don't cook very well and can scratch the old paintwork when you go over them, although I do find they do more damage to the underneath when you reverse back over them for a second attempt.
I live near enough in the middle of a smallish Oxfordshire town, there is a horsey type that lives round the corner from us who seems to insist on riding said nag down what is a pretty busy residential street, with kids in it, said horse is well skitty with cars and often does the large ones all the way down the road, does she come and pick it up? does she hell... OF course if it was a dog owner allowing their animal to foul the street then she would be one of the first on the phone to the 'grass yer neighbours' up phone line run by the local council. Horses/bikes? on the road? hate em. Their the reason god invented bull bars :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by millenaire on Mon Apr 11, 2011 11:29 pm
I fitted new fog lights to my truck today, it never had any, so had to wire in a loom and relay and switch too.
I bought the Ring fitting kit which made things sooo easy, Looks the dogs danglies now too.
I spent a lot of money on booze, birds and fast cars. The rest I just squandered.
millenaire
Vehicle Name: Black Beast of Arrrgggh
Modifications: Fitted Bose sound system from my now scrapped Alfa Romeo, fitted some tasty spot and fog lights. Fixed speedo problem, cleaned egr and sorted vac pipe issues.
Hammerite and Waxoyl underneath, it's got new discs, pads and copper brake pipes all round. watch this space for the next exciting installment lol.
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Tue Apr 12, 2011 2:37 am
Rich; All the factors round here were either out of stock, or didn't do it and referred me to Vx. Milner's are out of stock too, as are Vx Green Parts, and while Hound Dog managed to locate one at a good price, I'd already spoken to South Wales Props (ta Dwifty :D ) Who said I could have one posted that afternoon for a gnats under £30 all in. Paid up there and then, so that'll be sorted at the weekend no doubt.
Snapper; Sadly no matter what had actually happened, if I'd hit the bike, guess who'd have got the blame, and as a full time driver, I cannae take stupid risks. Cyclists are a pet hate of mine, given their general attitude, and suicidal nature (penchant for having headphone on whilst riding, and no lights, etc, at night) but nothing seems to get done, and as above should anything happen, it's us nasty polluting car drivers who get the blame.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Tue Apr 12, 2011 7:40 am
the same as yesterday..looked at it, patted it's bonnet and told it that it will run again..and it will go to the ball (annual)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by roiphil on Tue Apr 12, 2011 3:53 pm
2 inch suspension lift finally done :party:
In Southern Ireland
94 Frontera Sport 2.0I
I can see the mountains so its going to rain !
i cant see the mountains so its raining !
roiphil
Registration Year: 1994/M
Vehicle Name: Jeep
Modifications: Southern Ireland
Southern Ireland number plates
Immobiliser immobilised as it was a pain in the 4rse
Converted to commercial
Wrap around bullbar, driving lights and fog lights
Roof Bar Lights
(come at me with your full beams boy racers and you get an eyefull of 10 lights)
Rear light guards bumper and body ones
LWB Rear Body Lights
Rock Sliders
(I like my allround protection)
255/75 R15 Kumho
Pajero Seats
38mm Wheel Spacers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Tue Apr 12, 2011 4:31 pm
Washed and polished her today for the first time :shock: ,i normally leave it for the rain and over grown lanes to clean her :rotfl:
It will rain tomorrow knowing my luck :lol:
4G WiFi
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Tue Apr 12, 2011 5:04 pm
played with the lights
