Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Mon Apr 13, 2009 5:29 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Mon Apr 13, 2009 6:31 pm
i'll pop my head in at some point depending on work
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Mon Apr 13, 2009 7:33 pm
I did it....
Took the tools out and hid behind the blue one, made my approach from the rear unseen (favourite approach). 17mm socket, extension, breaker in hand. Slipped under her rear and went at the captives for the body.
It worked, she was unprepared and all 6 were cracked without a breaker amongst them :dance:
I hope to get the body lifted this week, then the axle the weekend. If I do the forklift work at work and leave the handbrake bits off till I get home will it be ok to drive? Can then sit on me drive while I do the fiddly stuff, its only half a mile from one to other.
p.s. may take up the technical assistance at that point if anyones free.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Mon Apr 13, 2009 7:50 pm
ime only a phone call away mate :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Mon Apr 13, 2009 7:54 pm
If I'm free and you need a photographer to document the process, you have my number.
Ooo, Alex, have you found a locking wheel nut key on your drive (tri-lock) - I seem to have mislaid it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stu on Mon Apr 13, 2009 7:57 pm
hold it to ramson alex . :wink: thats if you have it . :wink: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BadBoy on Mon Apr 13, 2009 8:01 pm
1 - Cut down the bull bars to A-frame type.
2 - Washed it!
Sounds boring?
It was the first time some parts have seen hot water in 13 months.
Just need to find the t-cut now to remove all the scratches from laning days :dance:
Skype Username: paul.bush21
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Mon Apr 13, 2009 8:04 pm
In a word no. But will have a scout. Did it lodge in a socket?
Wont know when I am playing till the lifts done and I have the new diff in hand. will have coffee and bisccuits at the ready.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Mon Apr 13, 2009 8:10 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Mon Apr 13, 2009 9:59 pm
I even got some cookies....
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Mon Apr 13, 2009 10:05 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Apr 13, 2009 11:33 pm
fitted my new rear glass struts, haha they lasted 2 openings and would not keep the glass up, oh well back to the piece of wood,
any one fancy doing my diff pinion seal
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dave_RAYNET on Tue Apr 14, 2009 12:13 am
well i sprayed the underside of my engine with "gunk" degreaser today in a bid to find where my oil leak is coming from.
The whole underside is soaked in oil, i thought it was the front crank seal but although there is some black crud there, it isn't wet or fresh.
I'm going to renew the rocker cover gasket as a matter of course anyway and re seal the bolt on plate. Got an MOT sometime around the 30th and could do with it not dribbling on the tester.
I've also noticed a hole in the sill below the rear passenger door. So far i've been told "it's not structural it won't fail the mot" and "it will fail the MOT and needs to be plated" :roll:
Will post a pic up tomorrow and get a general opinion, either way i know it'll need to be plated, holes in metal is never a good thing, unless it's a cheese grater!
Dave_RAYNET
Modifications: not yet
Skype Username: dave_m0yaa
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Tue Apr 14, 2009 5:35 am
without looking i can tell you it will fail a mot mate :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dave_RAYNET on Tue Apr 14, 2009 9:04 am
Dave_RAYNET
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Tue Apr 14, 2009 9:20 am
Especially near a seat belt mount or a body mount, both around there.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dave_RAYNET on Tue Apr 14, 2009 9:46 am
ba ba baaaaaaaaaaam.... here it is... my hole (ooo er missus)
now to me, failure or not, it needs sorting sooner than later. Given i can't weld i'll have to get it priced up :(
Dave_RAYNET
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Tue Apr 14, 2009 2:29 pm
It does mate, will want a plate as its too big for welding up. If you do a real nice job and paint over it, filler may be your friend. Just make sure you give both sides a treat of paint or it will be obvious and the tester may get Mr.magnet out and rumble you.
Expanding foam and plenty of body filler worked a treat on my carlton when i had it :dance: :shock: :lol:
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Tue Apr 14, 2009 4:36 pm
